Interleaving Request
- Interleaving Request
Re: Ping to bbc.co.uk
19-05-2013 2:04 PM
19-05-2013 2:18 PM
Noisy line...no
Call problems...no
OR in the cab...not that I've recently noticed.
Stats from prior to me going unlimited attached.
Edit: just a thought the street lighting on the main road nearby (where the cab is located) is currently undergoing an upgrade with new poles and hi-tech light heads so electrical work has been ongoing for a few weeks....just a thought.
19-05-2013 3:42 PM
Is any of this new street lighting operational yet?
19-05-2013 4:38 PM
Thanks Anotherone.
19-05-2013 4:56 PM
19-05-2013 10:31 PM
Not surprised considering the SNRM.....attached.
My PN profile is way behind now at 12Mbs.
20-05-2013 7:40 AM
There are obviously no regular spikes or 'events' on the SNR margin graph
So the DLM has dropped your target SNR margin to 3 (was 6)
and pushed up the Sync up to 16097.
Notice how its also increased the interleaving depth - which is a bit abnormal
Once the PN IP profile has been corrected, it will be interesting to see whether you can get the full expected download speed or whether the overhead of the increased interleaving level will be restricting it
I was wondering whether this would happen yesterday..............
20-05-2013 9:10 AM
I'm just studying these stats and will post back.
20-05-2013 9:35 AM
Speed prior to all this.....
Current speed...
Crazy stuff
20-05-2013 9:38 AM
21-05-2013 6:54 AM
First just a quick comment on the Upstream - the Errors are very low, certainly not worse, in fact strangely seem better, although there have been more Bit-swaps.
Now the Downstream -
Immediately prior to/at the point of the Event there was a significant increase in errors (rather obviously or DLM wouldn't have acted) but the very large number of SES errors suggest either a prolonged burst of noise/interference or multiple shorter bursts. This resulted in at least an order of magnitude increase in CRC errors and possibly slightly less of an increase in HEC & ES errors. However there seemed to be a decrease in the number of bit swaps which could possibly be interpreted as meaning that the noise was fairly broad spectrum affecting many tones and hence less possibility of swaps. Note that back in January there were only 8 SES errors in just over 19 days!
DLM applied Interleaving at depth 64, not exactly the lowest - not surprisingly CRC, HEC & ES errors were at a lower rate than on Fastpath however initially (over that 2 days of stats) the RS corrected errors were 0.5% of the total RS.
DLM was obviously unhappy about what seems to have been an increasing error rate and has now applied Interleaving at depth 128 & in these later stats over a 7 hour period the RS corrected errors have increased 10 fold and the RS uncorrected errors have increase by just over 15%.
DLM also seems to have lowered the Target SNRM
The CRC & HEC errors have increased and the ES errors are an order of magnitude bigger despite the increase in Interleaving depth. There is also significant SES errors compared to the initial Interleaved period when there were none.
Whether the latest stats will show a continuing deterioration or improvement remains to be seen. It seems rather co-incidental that works have been going on to install new street lighting. One has to question whether the trench digging etc has resulted in possible damage to a cable, maybe a power cable, not necessarily phone. Do you know where they were digging the day/time of the Event when you lost sync and Interleaving got applied Strat?
The other possibility I suppose is the proximity of a new electric cable close to a phone cable, but that is hypothesis as the phone cables could be overhead.
Check of course whether you end up with any crackling or other noises on the line when using the phone or any problems with incoming or outgoing calls which would indicate a phone line fault.
This also seems to be one of those rarer cases where DLM is not adjusting the line in the most sensible way, especially if ping time is more important than speed.
21-05-2013 9:44 AM
I don't have the answer to your question regarding digging. The main road in question is 1 mile in length and work has been going on, albeit sporadically, along it's entirety for a few weeks now.
I've attached a couple of screen shots....the SNRM has been down to 0.9 last night, the lowest I've ever seen.
21-05-2013 10:40 AM
The Bits/Tone looks fine - FYI the tones with no bits are standard, if you look above 255 you'll also see tones 291 & 348 without bits.
How's your gaming with Interleaving at this depth? What sort of ping times are you getting now?
21-05-2013 2:49 PM
I haven't done any gaming in the last 36 hours as my daughter presented me with a crashed Micro SD card with 1,200 irreplaceable photos to recover
Edit: I've just done a bit of gaming and it was well down to my usual standard, the connection is fine.
22-05-2013 2:27 PM
I think I'll leave interleaving as it is for now.
