Interleaving - Plusnet say it is off, router says it is on
- Interleaving - Plusnet say it is off, router says ...
16-06-2011 5:13 PM
TP-LINK> w ad ch
near-end interleaved channel bit rate: 7616 kbps
near-end fast channel bit rate: 0 kbps
far-end interleaved channel bit rate: 448 kbps
far-end fast channel bit rate: 0 kbps
And I have power cycled the router. Do I have to power off for a long time, or overnight or something? I'd like to try to get 8128 sync. SNRM is around 8 most of the time. Why does my router say it is on and Plusnet say it is off? Plusnet say I should ask in the forum as "Unfortunately this is not something we can offer that level of support on" which seems a odd answer to me. From where I'm standing it doesn't look like interleaving is switched off, unless there is some trick to activating it.
Re: Interleaving - Plusnet say it is off, router says it is on
16-06-2011 5:20 PM
16-06-2011 5:33 PM
17-06-2011 12:06 PM
What I get is currently
TP-LINK> w ad li f
relative capacity occupation: 54%
noise margin upstream: 20.0 db
output power downstream: 19.5 dbm
attenuation upstream: 10.5 db
carrier load: number of bits per symbol(tone)
tone 0- 31: 00 00 00 00 02 45 66 77 78 88 88 77 77 66 54 20
tone 32- 63: 00 00 00 34 56 78 89 aa ab bd bc cc cc cc cc cc
tone 64- 95: 0c cc cc cc cc cc cc cc cc cc cc cc bc bb cb bb
tone 96-127: bb bb bb bb bb bb bb bb bb bb ba bb bb ab aa aa
tone 128-159: aa aa aa aa aa aa aa aa aa aa aa aa aa aa aa aa
tone 160-191: aa aa aa aa aa aa 9a aa 9a 9a aa 9a 99 99 99 99
tone 192-223: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99
tone 224-255: 99 99 89 89 99 99 88 99 99 99 99 98 88 88 77 64
TP-LINK> w ad li n
relative capacity occupation: 96%
noise margin downstream: 6.0 db
output power upstream: 12.0 dbm
attenuation downstream: 24.0 db
TP-LINK> w ad li n
noise margin downstream: 4.5 db
so SNRM max 6dB, dropping down to 2 fairly often. But errors seems to be fixed at 3
TP-LINK> w ad perf
near-end FEC error fast: 0
near-end FEC error interleaved: 0
near-end CRC error fast: 3
near-end CRC error interleaved: 0
near-end HEC error fast: 3
near-end HEC error interleaved: 0
far-end FEC error fast: 0
far-end FEC error interleaved: 0
far-end CRC error fast: 0
far-end CRC error interleaved: 0
far-end HEC error fast: 0
far-end HEC error interleaved: 0
Error second in 15min : 0
Error second in 24hr : 1
Error second after power-up : 3
ADSL uptime 8:20:58
which perhaps was the re-sync to 8128? Is this anything to worry about?
20-06-2011 10:01 AM
Are you seeing any poor performance from your connection. As 8128 is the maximum sync I wouldn't worry about the SNR. As I've said before, unless you are having performance ssues with your internet then I wouldn't try to analyse router stats because they'll drive you insane!
Jojo
20-06-2011 10:34 AM
At most I seem to to see 1 error second (= in 1 second window had an error) in 15min, so 1 in 900 error. I reckon that's acceptable. Long term it says 58 error seconds since power up 79 hrs ago which is 1 in 4900.
21-06-2011 9:07 AM
10-07-2011 3:07 AM
10-07-2011 3:10 PM
Quote from: Malcb Thanks for the reply. I think performance is ok. Looking at the errors stats again I think what that is telling me is I have the odd error now and again but nothing to worry about.
When I turned interleaving off to get the 8128 speed, I was getting downstream SNRM that was 7.4-7.9dB most of the time, and ran at around 10 CRC errors per hour. It was no problem whatsoever.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
11-07-2011 8:34 AM
Puddy
