Interleaving [CLOSED]
- Interleaving [CLOSED]
- « Previous
- 1
- 2
- Next »
Re: Interleaving
01-12-2011 1:03 PM
Quote from: sjrinfroyle Is this limit forever?
No, if need be (i.e. as part of a fault investigation or whatever) then we'd be able to make the change. If it's a request to make changes just to test things or on a whim though I'm afraid it'd be unlikely that we'd place the order.
What is it that you're hoping will change though? Is interleaving affecting your use of the broadband? Bear in mind that if it is turned off and you're currently tweaking the SNR down to 6 that it's very likely the line will start to drop connection again.
@Nozzer - If interleaving is set to Auto the SNR will default it to off initially, though as it's set to auto it may well turn on depending on the line quality. If it's set to always on or always off though it won't change the state.
Re: Interleaving
01-12-2011 1:09 PM
@sjrinfroyle... your router will report what the current state of interleaving is on your line, not whether the DLM is set to automatically turn it on or off. I would suggest that your interleaving is currently set to auto, with the current state turned on because it needs it. Atificially tweaking your SNR during the training period won't help things much.
Matt might be able to confirm whether your interleaving is set to auto and currently turned on?
Re: Interleaving
01-12-2011 1:16 PM
Quote from: nozzer Matt might be able to confirm whether your interleaving is set to auto and currently turned on?
That would be useful.
Re: Interleaving
01-12-2011 1:37 PM
Re: Interleaving
01-12-2011 1:38 PM
Quote from: Matt it's been set to auto and is currently turned on.
Thanks Matt. How long should it take for the IP profile to increase?
Re: Interleaving
01-12-2011 2:02 PM
Re: Interleaving
01-12-2011 2:04 PM
Quote from: Matt provided it stays stable it should uplift in around 3 days.
Okay, thanks Matt. I just have one more question for you: if the target SNR was to be reset to 6dB would the interleaving be turned off at the start?
Re: Interleaving
01-12-2011 2:11 PM
Re: Interleaving
01-12-2011 2:13 PM
Re: Interleaving
01-12-2011 5:00 PM
Re: Interleaving
01-12-2011 5:21 PM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13227600175577.png" />
Looks like it's not stable at all at 6dB, I suspect the best thing would be to leave the DLM system to do its thing and train the line to the best compromise of speed and stability.
Re: Interleaving
01-12-2011 5:22 PM
Re: Interleaving
01-12-2011 5:29 PM
Re: Interleaving [CLOSED]
01-12-2011 5:32 PM
Thanks.
01-12-2011 5:38 PM
If there is any reason why another poster would like it resurrecting please send me a PM
- « Previous
- 1
- 2
- Next »
