Interleave and SNR request
Shell12
Hi Could someone please get my interleaving switched to on and SNR reset back from 9 to 6db please
Fixes: 62
Re: Interleave and SNR request
I've submitted the SNR reset and have placed an order to change interleaving from auto to on.
 Adam Walker
Shell12
Thanks Adam
Shell12
Hi SNR is still at 9db and interleaving is still off could someone check it out for me please
Just had a look, it seems the reset is going through but I've submitted another one anyway just to be sure - hope it takes effect.
Shell12
Hi
Interleaving is still not switched from auto to on and SNR is still at 9db
could someone please help
Fixes: 162
I'll try as 2 separate orders. SNR reset first as this happens within a few minutes, then I'll place the interleaving order which should complete tomorrow.
 Chris Parr
 Plusnet Staff
Shell12
Thanks Chris i have my 6db back
also i now have an ip profile of 14Mbps but my pn profile is still at 12.4Mbps could someone give it a nudge please
Thanks again Chris and thanks to the rest of the pn team
Fixes: 162
That's done for you now.
 Chris Parr
 Plusnet Staff
