Interesting effect of double filtering the phone - any thoughts
edgeways
Re: Interesting effect of double filtering the phone - any thoughts
Hi old jim,
Just noticed this thread.
For what its worth, I have been using double filtering for a long time (only one phone in use- a dect )
I found that it gives me a slight improvement to snr, which is very welcome on my long line.
Mike (edgeways)
HPsauce
Seasoned Pro
Fixes: 5
Quote from: _Adam_Walker_
I can't see how that would cause a problem.
Just plug 2 together and look again, you'll see.  Wink
MJN
Fixes: 5
It might be more helpful, particularly for those that don't have/use plug-in filters, if you would explain what the observed problem is (and the reasonings why if you happen to know).
Mathew
jim:quote
Oldjim
Resting Legend
Fixes: 63
Quote from: Oldjim
Except that a filter connection wouldn't fit to the router side of the first filter so bad  Shocked
