Interesting effect of double filtering the phone - any thoughts
- Re: Interesting effect of double filtering the pho...
- « Previous
- 1
- 2
- Next »
Re: Interesting effect of double filtering the phone - any thoughts
19-05-2011 11:38 AM
Hi old jim,
Just noticed this thread.
For what its worth, I have been using double filtering for a long time (only one phone in use- a dect )
I found that it gives me a slight improvement to snr, which is very welcome on my long line.
Mike (edgeways)
Mike (edgeways)
Message 16 of 19
(1,849 Views)
19-05-2011 11:49 AM
Quote from: _Adam_Walker_ I can't see how that would cause a problem.
Just plug 2 together and look again, you'll see.
Message 17 of 19
(1,849 Views)
19-05-2011 1:33 PM
It might be more helpful, particularly for those that don't have/use plug-in filters, if you would explain what the observed problem is (and the reasonings why if you happen to know).
Mathew
jim:quote
Mathew
jim:quote
Message 18 of 19
(1,849 Views)
19-05-2011 1:36 PM
Quote from: Oldjim Except that a filter connection wouldn't fit to the router side of the first filter so bad
Message 19 of 19
(1,849 Views)
- « Previous
- 1
- 2
- Next »
