Installing new router - dreaded DLM!
shure
Hi all,
I'm going to be installing my new router (Asus RT-N66u) next Wednesday / Thursday, while at the same time pressing my old one (DG834PN) into service as a modem only on my superfast 8Mb line.  With me being a particular favourite of Murphy and his pesky legislation I don't anticipate this going smoothly first time and hence will require more than a couple of reboots and connections. I'm very worried that this will attract the dreaded DLM fairy and and as a result after installation will be the proud owner of a gleaming new router while the family will be shouting at me for crippling their internet.
Is there anything I can do to prevent this?  Cry
Re: Installing new router - dreaded DLM!
I always set up my routers offline before hooking them up to the live system - saves having to constantly reboot and risk DLM kicking in every time you make a change.
shure
But I'll have to connect to get updates (and reboot after that), won't I?  And I'm hoping there won't be any issues with putting the Netgear in Bridge mode but Lady Luck invariable kicks sand in my face.  How many times do you have to reconnect before DLM kicks in usually?
Plusnet Staff
Plusnet Staff
Fixes: 5
I think you'd be fine with this. DLM would probably make changes after 3 or 4 disconnects.
Chris Pettitt
Cloud Environments Engineer
shure
OK, thanks.  Keep my fingers crossed!
BTW, how will I know?  Any way to tell (apart from slower speeds, which could be something else of course!)
Plusnet Staff
Plusnet Staff
Fixes: 5
Well, to be sure, post back here once you've done it and I'll take a look for you Smiley
Chris Pettitt
shure
will do.  Thanks! Smiley
shure
Hi Chris,
all set up now.  Had to disconnect a few times as it put up a fight, but I won in the end Smiley
Would you check for me please?
Plusnet Staff
Plusnet Staff
Fixes: 5
I've just checked for you and DLM hasn't taken any action so you're all good! Smiley
Chris Pettitt
shure
That's great.  Many thanks!
