Installing new BT Master socket and rewiring
- Re: Installing new BT Master socket and rewiring
21-02-2009 4:29 PM
It is an older property with no BT Master socket - just sockets wired on the very old style junction boxes, and the wiring is very untidy.
I've suggested getting BT in to install a new master socket and re terminate and check the extension wiring.
Rather than go through the hassle of phoning BT , and their Indian call centres - is this something Plusnet could do on his behalf ??.
What would be the cost.
thanks
Mal
21-02-2009 5:36 PM
21-02-2009 5:45 PM
I think this situation is actually very shocking - and anti competitive. I know about the safety issue, but with electricty and gas - you don't have to have the electricity company or gas company do a very similar job.
Not sure how much the electricity companies charge to replace the master fuse for example.
It's only a 20 minute job to put in a master socket for goodness sake.
It's government / ofcomm rview is long overdue.
21-02-2009 5:48 PM
21-02-2009 5:51 PM
21-02-2009 6:06 PM
Crossed that bridge - although I was qualified to design, specify and work on high powered transmitters, with 20KV circuits, 400V three phase supplies, I was not allowed to rewire a 240V mains socket !!!. or in some instances change a light bulb.!!
I designed, planned and supervised the installation of a complete oil platform telephone system, complete with flame proof armoured cable, junction boxes and phonesetc etc for work in gas areas, yet when I got home I couldn't legally instal a telephone extension in the house.
21-02-2009 6:53 PM
Quote from: pierre_pierre not strictly true about gas Mal, it is illegal to do your own gas work, it has to be a Registered Corgi Fitter and nearly as bad with electrics, you can do some work but not much
Believe you can do your own gas work but if you employ a person to do it they have to be corgi registered.
21-02-2009 7:02 PM
Technically it's against BT rules, but not AFAIK against the law of the land.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
21-02-2009 7:08 PM
21-02-2009 7:15 PM
21-02-2009 7:20 PM
21-02-2009 8:07 PM
Edit... Knew I had seen it somewhere, not sure if there is a call out with this though http://www.serviceview.bt.com/list/public/current/Exch_Lines_boo/0002_d0e63.htm#0002-d0e63
This is the forum post it came from http://community.plus.net/forum/index.php/topic,69349.16.html
Hope it helps.
21-02-2009 8:17 PM
Quote from: itsme some moron wire it up to the mains.
If it wasn't so serious it would be hilarious Sorry but I can't help but laugh at the thought of it. 13amp inline fuse on your phone line....
21-02-2009 9:28 PM
21-02-2009 9:58 PM
That was when I had someone else asking me.
Looks like we will see if there is a telephone line "fault"
But the answers I wanted was there - PN can't get it done.
thanks again all.
Mal
