Installation
CatBuck
Installation
I'm awaiting openreach to come with a cheery picker, I'm getting the run around and all Plusnet can offer is that they are unable to escalate until the 26th 7 days after the part installation
Tags (1)
1 REPLY 1
Fixes: 253
Re: Installation
@CatBuck
A warm welcome to the forums.
Unfortunately if BT Openreach have told their customer (the ISP) the next update in in N days, BTOR will not under any circumstances entertain a chase or escalation before N days.  The "run around" you are getting is the same "run around" PlusNet is getting from Openreach.
BT Openreach dictate the timeframe and scenarios within which an ISP can escalate issues ... such restrictions do not apply to Joe Public.  People in your situation emailing the CEO of BT Openreach directly have seen their longstanding issues resolved in hours.  The DSO can cut through the wait N days until the next update / option to escalate nonsence.
That said, left to itself, the issue could be resolved sooner than the N days ... that time frame is simply the next update projection.
EDIT: See here - https://community.plus.net/t5/Full-Fibre/Full-fibre-install-delayed-3-months-for-civil-works-but-civ...
