Installation without Router
bandaid
Installation is tomorrow and my router is stuck in some Post-Office sorting hell-hole.
Tech-support tell me that I'll be able to connect a single PC to the modem - PPPoE? Is there a guide available that has the details? I'd like to have a run-through to make sure there are no gotchas.
cheers,
Fixes: 50
Re: Installation without Router
There's a step by step guide here ( for Windows XP )  http://community.plus.net/library/broadband/fibre-help-setting-up-a-pppoe-dialler-for-windows-xp/ .
Windows 7 is similar.
Fixes: 54
bandaid
Cheers, people
Fixes: 221
and welcome to the forums bandaid, hope your installation is a smooth one Smiley
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
