Installation of phpbb
- Installation of phpbb
27-09-2007 9:24 AM
For a non-techy person like me this has been a nightmare! I have got to the page where you install the phpbb and put in the database name and password but it just says phpBB : Critical Error Could not connect to the database.
F9 say there is a misconfiguration on the MySQL settings you have entered.
I have left everything as it comes up, MySQL3x and as local host. Do you change the domain name too?
Message 1 of 3
(1,024 Views)
2 REPLIES 2
Re: Installation of phpbb
27-09-2007 12:43 PM
Hi Thanks for helping. I have switched on the MySQL and that tutorial was the one I was following but gives no help at that page unfortunately...Aaaagh!
Message 2 of 3
(347 Views)
27-09-2007 1:48 PM
Host needs to be rumpus or humbug as detailed in the MySQL activation email you should have received. You also use the MySQL login & password given in the email, not your plusnet portal ones in case that is what you did.
Dd you specify the database name which will be <username>_<visp> e.g. fredboggs_pn for plusnet
Message 3 of 3
(347 Views)
