Information required please 'How to reset/reboot the BT FTTC modem'
- Information required please 'How to reset/reboot t...
18-10-2013 9:31 PM
I've recently had PlusNet Fibre Unlimited (FTTC) fitted.
For future reference, could someone please tell me the correct method to reset/reboot the BT Openreach (FTTC) modem that is connected to my Netgear DGND4000 router.
I don't want to give the DLM an excuse to lower my sync speed, should I ever have a problem !!
Message 1 of 6
(4,592 Views)
5 REPLIES 5
Re: Information required please 'How to reset/reboot the BT FTTC modem'
18-10-2013 9:33 PM
I normally go into the router, manually disconnect, turn off the router, turn off the BT Modem then wait at least 5 minutes before turning back on so the DLM has no doubt that it is an intended disconnect.
Message 2 of 6
(2,196 Views)
18-10-2013 9:40 PM
Thanks picbits for the speedy reply.
I'll keep your method in mind ... hopefully I never need to use it !
Thanks again
Thanks again
Message 3 of 6
(2,196 Views)
18-10-2013 9:43 PM
To be honest with you, I've had a couple of times where the router has locked up and I've had to do a complete power off of both units simultaneously (my router / modem are a bit hard to get to) so killed the power at the socket. I've waited a few minutes then powered back up with no apparent ill effects but I much prefer the more controlled approach
Message 4 of 6
(2,196 Views)
18-10-2013 10:00 PM
Check this for power cycling the BT FTTC modem:
http://bt.custhelp.com/app/answers/detail/a_id/13767
Message 5 of 6
(2,196 Views)
18-10-2013 10:26 PM
Thanks khaled35 for the link ... it's now bookmarked !
picbits like you, I also prefer the more controlled approach. I've read that the DLM can be very aggressive, hence I wanted to know the correct method
Message 6 of 6
(2,196 Views)
