Info Oct 29 08:52:35 LOGIN User xdsl info expand=enabled tried to log in on ..
All Star
Fixes: 6
Not a major concern, but I get the above line in the router logs every so often -once an hour for 3 or 4 hours, then a gap, then the same again.
Is this anything to be concerned about?
Note that I don't go into the router that often, so don't know when it started, or how regular it is.
Fixes: 17
Re: Info Oct 29 08:52:35 LOGIN User xdsl info expand=enabled tried to log in on ..
It's some problem with whatever stats monitoring program you are running, but I thought RouterStats Lite doesn't use telnet?
All Star
Fixes: 6
Thanks for the reply, ejs. That thought was in my head too. I didn't think RSL  used tenet either.
Could be wrong, though - I have v10.0 installed and the is definitely a tab marked 'Telnet Raw Data'. Huh
