Infinity installed on my exchange but not available to me
- Infinity installed on my exchange but not availabl...
17-08-2011 9:30 AM
I can get 1mb maximum, in practice often less. BBC i-player needs 2mb. Increasingly I hear people complaining that they 'can only get 2mb'.
What is the chance of my line being upgraded? The fact that my exchange has been enabled but not my line makes it seem less hopeful to me.
Re: Infinity installed on my exchange but not available to me
17-08-2011 9:44 AM
This cabinet in a word "connects" the copper your current ADSL service uses with the fibre to the exchange.
You should see one appear soon hopefully I'm unaware of a place to check install dates for them though
17-08-2011 11:07 AM
17-08-2011 12:22 PM
That is the new style of cabinet typically used.
I can't find another which I have seen which is an older larger cabinet that simply has a new sort of "door bolted on".
But the above one pictured is the one most used.
17-08-2011 12:33 PM
I'm in the same boat. My exchange has been fibre active since early to mid 2010, but still there are no signs of it ever coming to me. Although, there was a fibre cabinet installed in my street over 2 months ago, but there's still no date or any other info available to me.
Fibre cabinets are normally installed within 3 or 4 meters of the old cabinet, since they connect directly to the old ones (As i'm told). They do look different, but not alot different. It's still a green box, but shinier, often larger and usually has vents on the front.
17-08-2011 12:37 PM
Quote from: Stewthecue Basically BT upgrade the cabinets that they feel will be easiest, not the most deserving. This is so they can keep their promise of 1 million homes served by 2012 or whatever it was.
Green box, larger,shinier?
What like the one I posted ? 😛
17-08-2011 12:38 PM
17-08-2011 12:53 PM
They also have the yellow electric 'lightning' warning icon.
Quote from: Stewthecue They do look different, but not alot different. It's still a green box, but shinier, often larger and usually has vents on the front.
Naughty thought: with the vents as low as they are, I hope the dogs can read.
17-08-2011 12:55 PM
That may be a small amount of the decision making, but there are a number of factors, including BT's Profit. They aren't a charity, so if they think they are unlikely to even make their money back from a particular cabinet then they may not. Also to consider is whether there is room in the vacinity of the existing cabinet to site the new one. The new one also needs electric, so there needs to be somewhere for them to draw that from, such as a streetlight. Then they need to apply for planning permission, so if the council stall on this, or refuse it, then there could be more delays or the possibility of it not getting done at all.
Phil
17-08-2011 1:03 PM
17-08-2011 1:11 PM
http://www.yourlocalguardian.co.uk/news/local/topstories/9050332.Resident_s_anger_over_BT_cabinet_in...
http://www.southportvisiter.co.uk/southport-news/southport-southport-news/2011/08/11/anger-at-huge-b...
and one where Openreach had to move cabinets.
http://www.itpro.co.uk/618424/bt-gives-in-to-planning-regs-and-moves-fttc-cabinets
17-08-2011 1:19 PM
Phil
17-08-2011 4:14 PM
Just to make it worse, I checked the houses round the corner (just a few yards) from me and even without fibre they are getting 2mb ie double my speed. Frustrating.
17-08-2011 5:28 PM
have you done the obvious and checked your house telephone socket wiring.
It worked for me and \I have gone from 1.5Mbps to 4.3Mbps. see this thread http://community.plus.net/forum/index.php/topic,97499.48.html
To be is to do - Kant
do be do be do - Sinatra
17-08-2011 5:46 PM
