Inexplicable Broadband speed drop
FIXED- Subscribe to RSS Feed
- Re: Inexplicable Broadband speed drop
21-04-2020 11:26 PM
For some unknown reason, my broadband download speed has dropped from ~6mbps to ~380kbps.
Upload speed is down from ~1mbps to 750kbps. This applies to both RJ45 and WiFi connections to the route
The dialing tone is string and clear, there is no background noise on calls, the router is plugged into the master ADSL socket and all of the wiring is in good condition and unchanged, and the router is less than a year old.
I have also tried restarting the router
The router reports:
1 - Product name: | Plusnet Router |
2 - Serial number: | **************** |
3 - Firmware version: | 7.275.11_F2704N_Plusnet |
4 - Board version: | F@ST2704N |
5 - Mode | ADSL |
6 - Uptime: | 0 days 14:04:31 |
7 - Data rate: | 895/7491 |
8 - Maximum data rate: | 924/7556 |
9 - Noise margin: | 6.5/3.0 |
10 - Line attenuation: | 22.0/44.0 |
12 - Data sent/received: | 22.9M/63.4M |
20 - Broadband username: | ***************** |
21 - Wi-Fi network/SSID: | ***************** |
22 - Wi-Fi connections: | Enable(802.11 b/g/n(up to 144 Mb/s))20 MHz WPS enabled |
23 - Wi-Fi security: | WPA2 |
24 - Wi-Fi channel: | Automatic (Smart Wireless) |
25 - Firewall: | Default |
26 - MAC Address: | ************* |
27 - Software variant | Version 1.0 |
28 - Boot loader: | 7.275.11 |
Any idea how this can be fixed because I can't work from home with this bandwidth?
Fixed! Go to the fix.
22-04-2020 7:41 AM
@SFJSmith From looking at your router statistics, you are getting a reasonable connection speed for your attenuation, but the downstream SNR looks a little low - I would have expected that to have been at least 6dB.
How did you determine your speed was ~380kbps?
22-04-2020 7:54 AM
22-04-2020 8:12 AM
Thanks for that information. Sorry to hear of your loss.
As your reported connection speed to the exchange is roughly where I'd expect it to be given your reported d/s attenuation, I can't honestly explain your disappointingly low results, although that 3dB noise margin certainly won't be helping it shouldn't result in such a low speed.
Just as a point of interest, are you disabling wireless when running the tests wired? Sometimes, even when you think you are using the wired connection, unless you explicitly disable wireless, it will still use that connection.
22-04-2020 9:43 AM
22-04-2020 10:29 AM
OK, definately a cable connection then, but reading your router statistics page says you are connected at a reasonable speed. I'm no expert, but the figures (to me) point to a local issue.
22-04-2020 12:16 PM
23-04-2020 5:03 PM
Hi @SFJSmith, thanks for getting in touch on our forums.
I am very sorry for your loss, please accept my sincerest condolences.
I have tested your line and we are seeing a sync speed of 5.8mb with no faults detected; the SNR is at 3dB and so I have now increased this for you as there has been a few drops today.
If you continue to have issues once connected into the test socket, please log a fault here so we can investigate further for you.
23-04-2020 10:26 PM
Thanks for condolences and for adjusting my line. The drops would have been me examining the ADSL master socket this morning where I found some crud had ingressed and, once I'd cleaned it out, the download speed was back up to 5Mbps. Hopefully, it won't recur but at least I'll know where to look first. ☺
23-04-2020 10:46 PM
Just curious - would this be a Master Socket 5C?
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
24-04-2020 1:49 PM
Thanks for getting back to me @SFJSmith, I am glad to hear things have improved. Just get back to us if there's any further issues.
24-04-2020 5:30 PM
24-04-2020 5:34 PM
OK, thanks.
