Incredibly Slow Speed
- Re: Incredibly Slow Speed
20-05-2021 12:36 PM - edited 20-05-2021 12:37 PM
I shouldnt have to post here again but whatever.
Internet is running at 0.2mbps and has been for 5 days now, I've had a fault ticket open for that same amount of time but apart from the usual 'replace everything and run it through the Master Socket' message I've had no reply from Plusnet at all
BTWholesale test give me this
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
and the Plusnet Router give me this
8. Noise margin: | 10.9 / 29.3 |
9. Line attenuation: | 19.6 / 38.9 |
10. Signal attenuation: | 19.6 / 36.2 |
The last time this happened it turned out ot be that my line was banded and all Plusnet did was reset my line and removed the banding
Please just do ANYTHING Plusnet
I can guarantee that I'm still being charged for this week of dial up speed 'broadband'
20-05-2021 12:41 PM
@Robert88 From those very abridged stats, you have a major problem. In order for other Community members to help, the full Help Desk information, with personal details redacted would be helpful. Also, have you checked your land line for noise?
20-05-2021 1:06 PM
Land line is crystal clear
Here are some more details
The recent bad weather did cause the router to reset a few times in fairly quick succession, which is what caused the line to be banded last time so there is that
20-05-2021 1:13 PM
OK. Next question - have you moved from ADSL to FTTC recently, or were you always on it?
Those SNR figures, and data rates, look very strange/worrying.
20-05-2021 1:18 PM
Nope absolutely nothing has changed with packages or anything like that, always been ADSL
Speed was averaging 6-7+mbps last week
Bad weather caused multiple resets
Speed is now 0,2mbps
This has all heppened before in almost exactly the same way, speed is good, multiple resets happen, speed becomes very poor until Plusnet resets the line
20-05-2021 1:21 PM
I'm confused - your maximum upload data rate is impossible on ADSL and you are running a Hub1.
20-05-2021 1:25 PM
The upload speed is never above 1mbps regardless of what it says anywhere
The Hub 1 was from Plusnet who years ago said that it would fix my slow speed (May have been the last time this happened?)
It didn't
20-05-2021 1:37 PM
OK, understand the hub situation now. I'm afraid there is little I can really suggest at the moment, but there are Help Team members around. Hopefully one of them will be kind enough to have a look, and (hint,hint) provide a Radius Log and GEA test report.
20-05-2021 3:38 PM - edited 20-05-2021 3:39 PM
Thanks for your post @Robert88
I'm sorry to see you're experiencing speed issues. Our tests are showing your line's banded at a max of approx 0.2mbps but line tests aren't showing the cause for this. On the face of things I suspect it's due to the drops you've had as pictured below, but you reported the problem before those drops.
I've reset your line to remove the banding, but if you get further issues we may need to look at arranging an engineer visit to investigate further. Let us know how it goes over the next day or so.
If you're interested I've attached a copy of our testing below (from before the reset)
xDSL Status Check | |||
Circuit ID: | [redacted CBUK] | Service ID: | [redacted BBEU] |
Telephone NO.: | NA | Test Executed On: | 20-05-2021 15:29:28 |
xDSL Status Test Summary | |||||
Sync Status: | Circuit In Sync | ||||
General Information | |||||
NTE Status: | NTE Power Status: | Unknown | Bypass Status: |
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 19.6 | 38.9 |
SNR Margin: | 10.8 | 28.7 |
Errored Seconds: | 0 | 0 |
HEC Errors: | 0 | |
Cell Count: | 43206 | 570058 |
Speed: | 828 | 284 |
Maximum Stable Rate (KBPS): | 10208 | Fault Threshold Rate (KBPS): | 8166 | ||
Mean Time Between Retrains (Seconds): | 21510 | Mean Time Between Errors Upstream (Seconds): | 5377 | ||
Indicative Line Quality: | A | Mean Time Between Errors Downstream (Seconds): | 86400 | ||
Custom Thresholds | |||||
MTBR_RED: | MTBE_RED: | ||||
MTBR_GREEN: | MTBE_GREEN: |
And the diagnostics after the reset:
Upstream Link Info
Loop Loss | SNR Margin | Errored Seconds | Hec Errors | Cell Count | Speed |
19.8 | 10.1 | 0 | 0 | 159737 | 828 |
Downstream Link Info
39.3 | 6.2 | 1 | N/A | 3623011 | 10720 |
Downstream BIP Interface Data
Current Line Rate | Line Rate Change TimeStamp | Maximum Stable Rate Recalculated | Profile TimeStamp | Maximum Stable Rate | Fault Threshold Rate | Interleaving Flag |
250 | 19/05/2021 03:16:08 | N | 10/05/2021 03:39:44 | 10208 | 8166 | A |
20-05-2021 3:52 PM
@Robert88 Any chance of your Help Desk tab sometime mid-morning tomorrow?
21-05-2021 3:02 PM - edited 21-05-2021 3:02 PM
@Gandalf wrote:
I've reset your line to remove the banding, ...
Upstream Link Info
Loop Loss SNR Margin Errored Seconds Hec Errors Cell Count Speed
19.8 10.1 0 0 159737 828
39.3 6.2 1 N/A 3623011 10720
Is that US still banded / capped?
21-05-2021 3:27 PM
@Townman The upload speed's not capped because if it were it'd be at around 0.4mbps. Interleaving is enabled on the line which would likely be the reason it's stuck at about 0.8mbps. I can remove interleaving but it may cause further issues if there's an underlying issue. Let's see what @Robert88 comes back with if they have any problems with their speed now.
21-05-2021 7:58 PM - edited 21-05-2021 8:17 PM
Almost forgot
Everything has been fine since the reset yesterday, no problems at all
4. Board version: | Plusnet Hub One |
5. DSL uptime: | 1 days, 04:22:43 |
6. Data rate: | 828 / 10722 |
7. Maximum data rate: | 21118 / 10692 |
8. Noise margin: | 9.9 / 5.5 |
9. Line attenuation: | 19.8 / 39.3 |
10. Signal attenuation: | 19.8 / 37.7 |
11. Data sent/received: | 3.2 GB / 87.9 GB |
12. Broadband username: | --------@plusdsl.net |
13. 2.4 GHz Wireless network/SSID: | PLUSNET-TSFS |
14. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 144 Mb/s)) |
15. 2.4 GHz Wireless security: | WPA2 |
16. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
17. 5 GHz Wireless network/SSID: | PLUSNET-TSFS |
18. 5 GHz Wireless connections: | Enabled (802.11 a/n/ac (up to 1300 Mb/s)) |
19. 5 GHz Wireless security: | WPA2 |
20. 5 GHz Wireless channel: | Automatic (Smart Wireless) |
21. Firewall: | Default |
22. MAC Address: | a8:9a:93:2c:ee:b4 |
23. VPI/VCI: | 0 / 38 |
24. Modulation: | G.992.5 Annex A |
25. Latency type: | Interleaved |
26. Software variant: | AA |
27. Boot loader: | 1.0.0 |
21-05-2021 8:12 PM
Looks much better - but I'm a little confused by the reported maximum upload rate - is there something suspicious there, @Gandalf ?
21-05-2021 8:18 PM
@jab1 I wondered about that too, but it is the same in post 3. Might be a Hub1 running in an ADSL line peculiarity!
