Increasing wifi range
- Re: Increasing wifi range
15-10-2012 10:55 AM
I have just moved to Plusnet from BT and now have my new PN router installed. As with BT (Home Hub 3) I have a dead area in one end of the house - its the furthest from the router and in an extension, so there is a double skin brick wall in the way.
I am wondering if there is some way I can configure the HomeHub3 to extend the range?
If not, what is the best solution?
Many thanks!
Many thanks!
Message 1 of 6
(1,136 Views)
5 REPLIES 5
15-10-2012 11:47 AM
I'm in exactly the same situation. The router is in the extension on the other side of a double-skin formerly external wall.
Since my PCs were also some way away from the router (and they don't have wireless cards) I opted for Homeplugs. In particular I now use a Wireless Extender which sits inside the living room, while the router is plugged into another Homeplug. This effectively gives me a 200Mbps (max) network connection through the double-skin wall, and the wireless extender then gives a nice fat wi-fi signal all through the house (since it's now on the right side of the wall).
I have now disabled the wi-fi on the router, and all wi-fi devices connect to the Homeplug. It just provides a wireless access point, and uses the router's DHCP server to supply IP addresses. It's lock-downable via MAC addresses, and has it's own configuration web page.
There are other makes and manufacturers, but this is the one I use and gives you a good idea of price:
http://www.solwise.co.uk/net-powerline-av-pew-n.htm
-Dave
PS Alternately if you don't want to shell out money you could try altering the channel your wif-fi broadcasts on . Software like InSSIDer can tell you what channels are saturated and what channels are free in your area:
http://www.metageek.net/products/inssider/
-Dave
A tortoise? What's that?
You know what a turtle is? Same thing.
Message 2 of 6
(627 Views)
17-10-2012 1:57 PM
Thanks Dave. I will check out Homeplugs. I had been hoping I could frig my Homehub to act as a repeater (if that is the correct terminology..), but if not the Homeplug solution sounds ideal.
Message 3 of 6
(627 Views)
17-10-2012 2:08 PM
Theres nothing stopping you from keeping the ssids the same and having multiple wireless points in the house :)..
Message 4 of 6
(627 Views)
17-10-2012 5:46 PM
So could I use my oldrouter (HH3) as the second wireless point, and how do I configure it?
Thx!
Thx!
Message 5 of 6
(627 Views)
17-10-2012 5:59 PM
You can do it with a HH2 so the procedure might be the same
See http://www.filesaveas.com/jarviser/repeaterhubsimple.html
Message 6 of 6
(627 Views)
