Increasing upload speed
- Increasing upload speed
05-06-2013 2:06 PM
I had my upload speed reduced to 443k a few years ago as I wanted to maximise my download speed. Now that my sync rate is around 22500 with noise around 2, I can probably afford to increase that a little without losing too much off the top. What do you suggest would be the best ratio of upload to download I should go for. I don't do a lot of uploading, but I do a bit from time to time. Even doubling it will help. How high can I go before it affects the download?
Message 1 of 7
(943 Views)
6 REPLIES 6
Re: Increasing upload speed
05-06-2013 2:22 PM
You shouldn't lose anything off your downstream unless you go for Annex M, which will take some of the downstream bandwidth. However, I believe Annex M (up to around 1.5Mb upstream) is only available to business users. Annex A should give you upwards of 1Mb upstream at no additional cost, either in financial terms, or to your downstream synch.
Message 2 of 7
(560 Views)
05-06-2013 2:23 PM
Thanks for that. How do I go about having it increased, or is it something one of the PN team can do for me from here?
Message 3 of 7
(560 Views)
05-06-2013 2:25 PM
DCT should be able to action it from here.
Message 4 of 7
(560 Views)
05-06-2013 2:26 PM
Thanks.
OK DCT, would you kindly do the honours for me?
Message 5 of 7
(560 Views)
05-06-2013 2:41 PM
Hi esseff,
I've placed a modify order to uncap your upload speed, this will take effect from tomorrow.
Message 6 of 7
(560 Views)
05-06-2013 2:41 PM
Cheers Chris.
Message 7 of 7
(560 Views)
