Increasing WiFi Latency and packet loss
smudgeysmith
Hi All,
Wondering if you can help.  I'm having a lot of trouble with Wifi connectivity issues relating to latency and packet loss.
A router reboot normally resets the situation.
Example of ping times:
PING 192.168.1.254 (192.168.1.254): 56 data bytes
64 bytes from 192.168.1.254: icmp_seq=0 ttl=64 time=841.131 ms
64 bytes from 192.168.1.254: icmp_seq=1 ttl=64 time=240.567 ms
After router reboot:
64 bytes from 192.168.1.254: icmp_seq=104 ttl=64 time=7.453 ms
64 bytes from 192.168.1.254: icmp_seq=105 ttl=64 time=2.613 ms
64 bytes from 192.168.1.254: icmp_seq=106 ttl=64 time=2.423 ms
Signal quality is excellent, RSSI is -47 and Noise is -101.  I'm on channel 1. no other wifi networks on 1, and only one on 2.  Other networks are channel 6 an beyond.
Any ideas?
Regard,
G.
1 REPLY 1
Fixes: 1,600
Re: Increasing WiFi Latency and packet loss
Hi there.
I'm sorry to hear you're experiencing latency issues.
I've made a change to the settings on your line which should fix this.
If you're still having issues can you try a wired connection and let us know how it goes?
