Increase in Bit Errors on incoming phone call
Fifer
Hi
I've recently installed a new router and have noticed jumps in the Bit Errors.  On trying to eliminate how these are occurring i seem to have narrowed it down to incoming calls.  The last two calls the errors have increased by approx. 1500.  I can't say i noticed this on the router that i replaced.  I've recently had a new master socket replaced by BT after a line fault, this has increased my sync speeds to the router stats below.
The router is plugged into the master socket with a filter, one extension to cordless phone downstairs with a filter on this, no ring wire on extension.
Any thoughts on what is causing this and how to stop the errors, or do i need to be concerned as everything seems to be working OK?
Version Info
Firmware Version: 1.0.5 Build 140321 Rel.42949
Hardware Version: TD-W8968 V3 0x00000001
System Running Time: 5Day(s) 17:26:02
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Link Power State: L0
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (0.1 dB): 31 59
Attenuation (0.1 dB): 250 110
Output Power (0.1 dBm): 0 126
Attainable Rate (Kbps): 20,076 1,212
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 19,015 1,215 0 0
MSGc (# of bytes in overhead channel message): 51 12 0 0
B (# of bytes in Mux Data Frame): 225 37 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 3 4 0 0
R (# of check bytes in FEC Data Frame): 0 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.3797 0.9934 0.0 0.0
L (# of bits in PMD Data Frame): 4761 306 0 0
D (interleaver depth): 1 1 0 0
Delay (msec): 0 0 0.0 0.0
INP (DMT symbol): 0.00 0.00 0.0 0.0
Super Frames: 0 0 0 0
Super Frame Errors: 4,589 262 0 0
RS Words: 0 879,050 0 0
RS Correctable Errors: 0 0 0 0
RS Uncorrectable Errors: 0 0 0 0
HEC Errors: 18,877 311 0 0
OCD Errors: 186 0 0 0
LCD Errors: 186 0 0 0
Total Cells: 2,091,851,395 1,230,245,455 0 0
Data Cells: 33,735,374 3,173,651 0 0
Bit Errors: 0 16,007 0 0
Total ES: 2,946 173
Total SES: 24 0
Ron
1 REPLY
Fifer
Re: Increase in Bit Errors on incoming phone call
Could somebody with more technical knowledge give me some advice on this. The router is now in the test socket with a new adsl nation XF-1e filter. their is no phone connected and the Bit Errors still take a big jump on an incoming call, just tested with a call from my mobile.
Some stats below.
Device Info
Version Info
System Running Time: 0Day(s) 00:29:51
LAN Info
IPv4 LAN IP Address: 192.168.1.1
LAN MAC Address: e8:de:27:62:83:13
IPv6 IPV6 Address/Prefix Length: NULL
Auto Configuration: RADVD&DHCPv6
ADSL Info
Line State: Showtime
Line Rate - Upstream (Kbps): 1251
Line Rate - Downstream (Kbps): 19203
Internet Info
IPv4 Status: UP
WAN Type: ATM WAN
Layer2 Interface: atm1(0/3Cool
Connection Type: PPPoA
WAN IP Address: ************
Subnet Mask: 255.255.255.255
Default Gateway: 195.166.128.184
DNS Server (Primary, Secondary): 8.8.8.8, 8.8.4.4
Internet Up Time: 0Day(s) 00:28:42
Shortcut: Click here to view all WAN interface's status and troubleshooting information.
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Downstream Upstream
SNR Margin (0.1 dB): 31 60
Output Power (0.1 dBm): 0 129
Attainable Rate (Kbps): 20,304 1,264
Path 0 Path 1
Rate (Kbps): 19,203 1,251 0 0
B (# of bytes in Mux Data Frame): 227 38 0 0
S (ratio of FEC over PMD Data Frame length): 0.3793 0.9904 0.0 0.0
L (# of bits in PMD Data Frame): 4808 315 0 0
Super Frame Errors: 43 28 0 0
RS Words: 0 3,010,824 0 0
HEC Errors: 329 41 0 0
OCD Errors: 2 0 0 0
LCD Errors: 2 0 0 0
Total Cells: 81,847,752 5,305,724 0 0
Data Cells: 25,873 14,372 0 0
Bit Errors: 0 1,717 0 0
Total ES: 25 13
Total SES: 0 0
Total UAS: 49 49
would this indicate a line fault ?
Any advice would be much appreciated.
Ron
