Incorrect profile
- Incorrect profile
Incorrect profile
06-10-2009 9:58 AM
1. Your product type
Plusnet Value with included 10GB bandwidth
2. Your current usage from the VMBU
Paid-for usage 173.4MB 8am - Midnight
Paid-for allowance: Up-to 10GB 8am - Midnight
Free usage: 18.56MB Midnight - 8am
Total usage: 191.96MB
3. Your IP Profile, as reported by Plusnet
Current line speed: 1500
4. Information from the BT Speedtester
Your DSL connection Rate : 1792 Kbps(DOWN-STREAM), 448 KBPS)UP- STREAM)
IP Profile for your line is – 3000 Kbps
5. A Speedtest from an external testing site.
Date Download Speed Upload Speed
Tue Oct 6th 09:38 1454 kbps (182kB/s) 369 kbps (46.1kB/s)
6 Your gateway
You are currently connected to the "Telehouse East, Juniper 4" gateway. This gateway is sometimes known as pte-ag2.
7 Your exchange status
VP capacity at this exchange is currently showing as Green.
8. Any other information
26th September was last good connection at about 4 megs, since then its been as low as 128Kbps but in last two days has reached the dizzy heights of 1.4 megs.
Seriously concerned with the performance of PlusNet, however it is good to see that someone is collating all the speed problems – perhaps we will get a fix?
[Moderator's note by Adie (Adiewoo) adjusted title to reflect issue
6 Your gateway
Message 1 of 4
(778 Views)
3 REPLIES 3
Re: Broadband Speed Issues - 03/10/09
06-10-2009 9:59 AM
@ RonB
Sounds like we're just misprofiling your line after an IP Profile change. I'll get it changed now and you should see an improvement after a reboot of your router.
Message 2 of 4
(388 Views)
Re: Re: Broadband Speed Issues - 03/10/09
06-10-2009 10:11 AM
mod:note
Split from speed thread as it's a different issue.
Message 3 of 4
(388 Views)
Re: Incorrect profile
09-10-2009 4:54 PM
James - Thanks that did make a difference. Speed has increased from 1.4 megs to 2.6 megs - Still a long way from satisfactory though.
Why is it taking so long (since 26th September) to resolve this issue?
My latest stats are:-
IP Profile as reported by PlusNet
Estimated line speed:
8 Mbps - Checked on 2009-08-24 11:30:06
Current line speed:
3000
BT Speedtester
Download speed achieved during the test was - 2646 Kbps
Additional Information:
Your DSL Connection Rate :7968 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
Current line speed:
3000
BT Speedtester
Message 4 of 4
(388 Views)
