Incorrect profile
jkakwinstanley
Incorrect profile
I was wondering if it was normal for a house move of FTTC line to be limited to 40 down and 2 Mbps up?
I was expecting upload to be a little higher.
I've raised a ticket in case there is a problem #87959499.
Thanks,
J
Fixes: 62
Re: Incorrect profile
No it isn't
Somebody pressed the wrong button and you have been provisioned on the wrong product
DanHodby
I'll take a look for you J.
Give me a few minutes...
DanHodby
Oldjim was right, it was most definitely a miss click when the order was originally placed.
I've placed the order to correct this now so if you reboot your modem around this time tomorrow you should see abit of an increase Smiley
I hope this helps.
jkakwinstanley
Thanks. I'll check tomorrow after a modem reboot.
jkakwinstanley
Sorted.
38 down and 8 up.
Line stats from a bt speed test suggest I could have up to 50 down (obviously capped by my product at the moment). Is it likely that my up speed could increase as this states up to 20?
