Incorrect Plusnet IP Profile
goldenfibre
BT IP: 16.88Mb
PN IP: 16.5Mb
Fixes: 10
Re: Incorrect Plusnet IP Profile
Please explain what PRACTICAL difference such a small discrepancy is making to your use of the internet.
Had you noticed anything or was it just your obsession with continually checking and running tests that led you find the difference?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
goldenfibre
Speed is matter to me as I paid my service to Plusnet. 300Kbps is does matter!
Fixes: 10
If your line was so long that you could only sync at sub 2Mbps speeds, 300Kbps would be significant. But with speeds of over 16Mbps 300kbps is insignificant.
I repeat
Quote from: jelv
goldenfibre
This thread is between me & plusnet staff. Thanks. The local exchange will change to 16.8Mb on Plusnet IP in the next 72 hours anyway.
Fixes: 10
If you wish to have a private conversation with Plusnet the appropriate vehicle is using the questions/tickets system - not posting on an open forum.
goldenfibre
It's much quicker here than raise the ticket as ticket never picking up for more than 5 days! That's up to me to post here and that's what this forum is here for. Thanks.
Fixes: 55
As you have said the automated system will change the setting in a day or so. Don't see the problem with waiting.
David
goldenfibre
Ok, fine. I can wait then.
Stanman24
Sorry m8 But you will never get that
I had Att of 23 and rarely got over 18MB
only way of obtaining those speeds is dropping your snrm to 0
goldenfibre
I had snr of -0.1dB for 38 hours stable once no loss of sync rate.
Stanman24
no CRC problems ?
hmm is that on a dg834 ?
goldenfibre
only 5 CRC errors. Using dgnd3700v2 and mk2 original genuine bt openreach telephone adsl vdsl face plate with rfi filter on the master socket.
