Incorrect IP profile
Mardler
Broadband speed has been getting slower and a test shows the download at 2.99Mbps and line profiled at 3Mbps.
Hopefully, someone at PlusNet can increase the profile to the maximum asap.
TIA
Dmitchell
Re: Incorrect IP profile
Hi there Mardler.
I've checked over your line and found that the bRAS profile was set to 3mb.
I've now reset the line to bring the speed back up to 7150. You'll need to reboot your router in 4 hours to pick up the new speeds (8pm).
Let me know if you have any further issues.
Dean
Mardler
Thanks, Dean.
We'll try that and get back either way.
Mardler
Hi Deano,
Just reran BT speed check and:-
Download = 7.33Mbps
Upload = 0.39Mbps
Thanks!
Dmitchell
That's good to see!
Dean
Mardler
Will do and thanks again, Dean.
