Incorrect IP Profile
- Incorrect IP Profile
23-02-2014 11:04 PM
I've had my plusnet unlimited fibre for a couple of days now and all is okay with no unwanted disconnections but chatting on one of the other forums, I am advised that my IP Profile may be incorrectly set - it appears to be on 40/10 rather than the 80/20 unlimited I had ordered and am paying for.
I have used an unlocked Huawei HG612 and put on in place of the supplied ECI one to get some stats and these are showing a LOT more attainable speed -- 60Mbps/15Mbps - than my current IP Profile of 37/10 (from the BT DSL Speed Checker) allows (d/l is at this limit). This ties in with others local to me and is quite a lot higher than the BT and Plusnet pre-connection estimate of 35Mbps d/l that I suspect this profile is based on. My previous ADLS2+ connection also had a higher actual connection speed than estimated (10Mbps vs 7Mbps) and could be run at a margin of 3db for long periods on a very quiet line.
Attcahed is a graph for the past few hours of Actual vs Attainable speeds to demonstrate
So is there a chance that the profile can be raised please to a level more like it looks as though it should be and see what happens?
Tony
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 15123 Kbps, Downstream rate = 59936 Kbps
Path: 0, Upstream rate = 9995 Kbps, Downstream rate = 39973 Kbps
Bitswap: 1115 67
Path 0
OHF: 14023541 802306
OHFErr: 686 0
RS: 0 1646566
RSCorr: 0 2
RSUnCorr: 0 0
Total time = 11 hours 57 min 47 sec
FEC: 0 0
CRC: 686 0
ES: 379 0
SES: 0 0
UAS: 18 18
LOS: 0 0
LOF: 0 0
Tony
Message 1 of 7
(1,960 Views)
6 REPLIES 6
Re: Wrong IP Profile
24-02-2014 10:33 AM
Message 2 of 7
(677 Views)
24-02-2014 2:21 PM
Bumping this again for an answer please.....
dick:quote
Dick:red Please also note this forum rule[/color]
dick:quote
Message 3 of 7
(677 Views)
Re: Incorrect IP Profile
24-02-2014 2:28 PM
I've just taken a look at this for you.
You've been placed on 40/10 due to your estimates being lower than 40/10. As you're exceeding this I've placed an order for 80/20 for you. You should notice a change to the speed tomorrow morning, any time up til midday.
Message 4 of 7
(677 Views)
24-02-2014 3:58 PM
Thanks for doing that Chris, look forward to seeing the increase!
Tony
Tony
Message 5 of 7
(677 Views)
24-02-2014 6:14 PM
Where's the green with envy emoticon when you need it? Left Hurst Gardens 2 years ago and now on a 20CN only exchange in Wiltshire without a FTTC or 21CN date!
Message 6 of 7
(677 Views)
25-02-2014 8:38 AM
Quote from: Chris I've just taken a look at this for you.
Well the IP Profile changed at 01:00 or so this morning and at 06:00 not a lot had changed except the upload speed but after a modem power off/on all the speed testers are reporting around 56/12 Mbps on the new profile so that is a great result for a ~800m line length! I don't suppose it will last once more people are connected (I was first one on this cab [4] in Hurstpierpoint in West Sussex) due to crosstalk but whatever it's a lot faster than I had.
Many thanks again for your help.
Tony
Message 7 of 7
(677 Views)
