Inconsistent Download Speeds
FIXED- Subscribe to RSS Feed
- Inconsistent Download Speeds
09-04-2018 6:02 PM
My router gives me a sync speed of 10Mbs and generally downloads run at 8Mbs quite quick enough for most practical purposes.
Recently there have been spells where speed falls dramatically down to 1Mbs. Sometimes turning the router (choice of three from Netgear!) off and on again cures the problem, sometimes it does not. I am tolerant but this is tiresome.
Cables in the road were fixed a few months ago and BT kindly fitted me with a new wall box with an inclusive filter. Disconnecting the phone make no difference.
Any suggestions?
Fixed! Go to the fix.
Re: Inconsistent Download Speeds
10-04-2018 8:53 AM
Is the phone line quiet? Please post your full router stats.
10-04-2018 10:55 AM - edited 10-04-2018 11:10 AM
BT cabling is all outside the house and there are no internal additional devices. current stats, back to 7mbps download a shade lower than "normal".
ADSL Link | Downstream | Upstream |
Connection Speed | 10359 kbps | 1123 kbps |
Line Attenuation | 40.0 db | 15.8 db |
Noise Margin | 3.9 db | 5.6 db |
Numbers from router above. Phone line silent.
10-04-2018 12:04 PM
Hi @TeeGee,
Thanks for getting in touch. I'm sorry to hear that you're experiencing inconsistent download speeds.
I've tested your line and the test is picking a high number of errors. It appears that this is because the SNR margin is too low for the length of your line. I've adjusted this now. Please monitor your connection over the next couple of days and let us know if this hasn't resolved the issue.
For reference, today's test result is as follows:
xDSL Status Check | |||
Circuit ID: | XXXXXXXXX80 | Service ID: | XXXXXXXX09 |
Telephone NO.: | NA | Test Executed On: | 10-04-2018 11:52:49 |
xDSL Status Test Summary | |||||
Sync Status: | Circuit In Sync | ||||
General Information | |||||
NTE Status: | NTE Power Status: | PowerOn | Bypass Status: |
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 15.8 | 40.0 |
SNR Margin: | 5.5 | 3.8 |
Errored Seconds: | 1 | 10 |
HEC Errors: | 1 | |
Cell Count: | 250107 | 1877525 |
Speed: | 1123 | 10359 |
Maximum Stable Rate (KBPS): | 9088 | Fault Threshold Rate (KBPS): | 7270 | ||
Mean Time Between Retrains (Seconds): | 86400 | Mean Time Between Errors Upstream (Seconds): | 3443 | ||
Indicative Line Quality: | R | Mean Time Between Errors Downstream (Seconds): | 3 | ||
Custom Thresholds | |||||
MTBR_RED: | MTBE_RED: | ||||
MTBR_GREEN: | MTBE_GREEN: |
10-04-2018 2:04 PM - edited 10-04-2018 2:13 PM
At the reported synch speed, 7.3Mbps DATA download would be about right.
The low SNRM on the DS could give rise to errors (as reported by Emily) - however I did not see DS MTBE / MTBF figures. The US MTBE suggests just one error per hour, which is not a real concern.
I suggest that you avoid rebooting the router and see what transpires. Anther sight of your FULL router stats (including error counts) would be useful ... though if this is Netgear router that might be a tad difficult!
15-04-2018 8:47 PM - edited 15-04-2018 8:49 PM
Best shot at current stats. Seems stable now. Fingers crossed!
Connection Speed | 9484 kbps | 1127 kbps |
Noise Margin | 5.9 db |
5.8 db |
System Up Time 6 days 03:25:35 | |||||||||||||||||||||||||||||||||||||||||
Thanks all for assistance
16-04-2018 11:27 AM
