Impulse noise protection ?
- Re: Impulse noise protection ?
24-07-2012 11:58 AM
In my router i have the feature for Impulse noise protection. I understand it can help bad lines with a lot of noise.
Would it be useful for everyone or certain lines?
My stats are:
ADSL Link Downstream Upstream
Connection Speed 7520 kbps 1067 kbps
Line Attenuation 45.5 db 24.2 db
Noise Margin 5.1 db 4.9 db
My stats are:
Message 1 of 2
(944 Views)
1 REPLY 1
24-07-2012 1:56 PM
It's a case of try it and see. It won't have any effect if the MSAN you are connected to doesn't support this feature. You should compares pings as well as error rates, sync speed etc.
Message 2 of 2
(466 Views)
