Improving speed?
- Improving speed?
Re: Improving speed?
02-09-2014 6:02 PM
PS. when I say stats, I generally mean a text copy and paste of the DSL connection stats as per reply #22, but what's in your last post will do for this one.
02-09-2014 7:32 PM
Router now connected through faceplate, I've added an extra filter on the telephone.
Just for interest I quickly connected my DSO on the line "my"side" with no router or telephone connected - 50 Hz @ 2vP-P (image attached)
I can't see the humm originating from my house as the cable exits within 1m of the faceplate and no mains cables near.
So the $1M questions are:-
What might be causing the phone disconnect problem.
What could be the source of the hummmmm.
What can be done about it.
ATB
SN
DSL Connection Details
DSL Line (Wire Pair):
Line 1 (inner pair)
Protocol:
G.DMT Annex A
Downstream Rate:
1792 kbps
Upstream Rate:
448 kbps
Channel:
Interleaved
Current Noise Margin:
6.0 dB (Downstream), 14.0 dB (Upstream)
Current Attenuation:
63.0 dB (Downstream), 31.5 dB (Upstream)
Current Output Power:
17.1 dBm (Downstream), 12.3 dBm (Upstream)
DSLAM Vendor Information:
Country: {0xB5} Vendor: {IFTN} Specific: {0xB182}
PVC Info:
0/38
02-09-2014 8:00 PM
That's not good. You haven't got a sub-station in your back garden then? Does the phone line go underground or overhead and if the latter, does it share poles with electricity cables? Do any high voltage cables that feed local power supply transformers pass anywhere near the line at all?
The DSO.- Is the the ground side of the signal input isolated from mains earth or connected to it?
Have you got a DVM at all?
This clearly needs looking at more closely.
02-09-2014 8:18 PM
Don't have a substation in the garden, but I do have a Dilithium-Antimatter-Fusion-Reactor in the shed
There are no overhead LV or HV cables within 1/2mile (33kv on poles).
Phone line exits house at low level, up the side of the house to overhead to pole across the street.
I think the DSO ground is isolated from earth, I did test with the i/p reversed, the noise was the same.
I have Fluke DVM.
ATB
SN
02-09-2014 8:40 PM
Likewise check the DVM and if that's isolated you could see if you get a comparable RMS reading from that in due course.
If you have a spare phone lead, that is one with a BT plug on it, you could plug it into the filter and access the line via the filter, but may be try it daylight hours when the SNRM is above 6/6.5 just in case it causes the sync to drop.
PS. you could use your Dilithium-Antimatter-Fusion-Reactor as a UPS for the modem/router
02-09-2014 8:55 PM
DVM = 50mV RMS and measures a frequency of 50Hz
02-09-2014 10:03 PM
02-09-2014 10:11 PM
I'd still like to fix the phone call disconnect problem though. Anything more I can do this end?
ATB
SN
03-09-2014 7:46 AM
04-09-2014 8:35 AM
I have severalDG384 routers but these always connect at a lower sync speed than the 2 wire - this might mask the telephone problem?
I've ordered a Billion 7800N, which should be here today or tomorrow and I'll be able to run some tests over the W/E.
ATB
SN
04-09-2014 8:53 AM
04-09-2014 1:17 PM
New router just arrived so playtime later.
ATB
SN
04-09-2014 1:27 PM
04-09-2014 2:26 PM
04-09-2014 2:40 PM
