Improved Speed Desired
- Improved Speed Desired
- « Previous
- 1
- 2
- Next »
Re: Improved Speed Desired
31-07-2008 8:19 PM
Sorry searched all his posts and could not find what you were referring to 😞
Quote from: Jameseh Didn't Jeremy (axisofevil) have a way of getting it to stick to 6dB even when reboots were being performed?
Setting the SNRM slider in DMT to 10% got me the 9.8dB I have now, down from the 15dB I had earlier.
I am still stuck at 4.2Mbps even with
Downstream Upstream
Line Rate 7168 Kbps 448 Kbps
Noise Margin 9.8 dB 23.0 dB
I guess I will just have to sit tight and wait for BT to increase the speed. Resyncing with DMT did not improve things and I have no other leads to get my downstream increased above 4.2Mbps now the line is stable.
Bob
01-08-2008 10:26 AM
Just watch out for those power dips/cuts
Good Luck.
01-08-2008 6:01 PM
As previously noted the reliabilty of BT External Plant is the problem with providing reliable High Speed Broadband.
Bob
04-08-2008 11:40 AM
BT speedtest results
14.45hrs 31 July 2008 after system resynced using DMT software
DSL connection rate: 7168 kbps, 448 kbps
IP profile for your line is - 4500 kbps
Actual IP throughput achieved during the test was - 4038 kbps
08.50hrs 01 Aug 2008
DSL connection rate: 7200 kbps, 448 kbps
Actual IP throughput achieved during the test was - 4109 kbps
06.40 02 Aug 2008
IP profile for your line is - 6000 kbps
Actual IP throughput achieved during the test was - 4085 kbps
05.13 04 Aug 2008 Up time 3days 11hrs 50min
Your DSL connection rate: 7200 kbps, 448 kbps
Actual IP throughput achieved during the test was - 4073 kbps
Speed actually the same whereas the speedtest using the PN Speedtester showed an increase - se below.
Voyager 2110 results as follows (precised to save space)
10.45 on 31/7/08 Statistics Downstream Upstream
Line Rate 7200 Kbps 448 Kbps
Noise Margin 9.4 dB 23.0 dB
08.55 on 01/08/08 Line Rate 7200 Kbps 448 Kbps
Noise Margin 9.7 dB 23.0 dB
20.40 on 01/08/08 Line Rate 7200 Kbps 448 Kbps
Noise Margin 9.6 dB 23.0 dB
06.30 on 02/08/08 Line Rate 7200 Kbps 448 Kbps
10.12 on 02/08/08 Line Rate 7200 Kbps 448 Kbps
Noise Margin 9.0 dB 23.0 dB
05.05 on 04/08/08 Total up time 03:11:46:42
Noise Margin 9.9 dB 23.0 dB
07.30 on 04/08/08 after 2hour reboot
Line Rate 5568 Kbps 448 Kbps
Noise Margin 15.3 dB 23.0 dB
08.00 on 04/08/08 after reset using DMT tool
Line Rate 7072 Kbps 448 Kbps
10.10 on 04/08/08 Line Rate 7072 Kbps 448 Kbps
Noise Margin 10.3 dB 23.0 dB
11.00 on 04/08/08 Line Rate 7072 Kbps 448 Kbps
Noise Margin 10.1 dB 23.0 dB
PN speedtest results
Today 10:44 4324 kbps (541kB/s) 364 kbps (45.5kB/s)
Today 08:04 4315 kbps (539kB/s) 381 kbps (47.6kB/s)
Today 07:36 4758 kbps (595kB/s) 376 kbps (47kB/s)
Today 05:17 4250 kbps (531kB/s) 376 kbps (47kB/s)
Saturday 10:15 4155 kbps (519kB/s) 377 kbps (47.1kB/s)
Saturday 06:34 4253 kbps (532kB/s) 356 kbps (44.5kB/s)
Friday 21:04 4254 kbps (532kB/s) 378 kbps (47.3kB/s)
Friday 17:29 4242 kbps (530kB/s) 380 kbps (47.5kB/s)
Friday 09:07 4257 kbps (532kB/s) 377 kbps (47.1kB/s)
Friday 05:17 4249 kbps (531kB/s) 381 kbps (47.6kB/s)
Speed results show the increase in speed as a result of the 3days after which I foolishly rebooted thinking it would kick it into higher speed. As it was it droped down to its end July speeds so I reset it using DMT tool again.
04-08-2008 11:41 AM
Say the word and I'll get the request sent to BT today.
05-08-2008 12:29 AM
05-08-2008 3:23 PM
I just did a speedtest and it had jumped up from 4.2Mbps to 5.5Mbps, the IP Profile seems to edge upwards once the situation has stabilised. details :
Voyager 2110 results :-
after DMT reset
08.00hrs 04/08/08 Line Rate 7072 Kbps 448 Kbps
15.42hrs 04/08/2008 Line Rate 7072 Kbps 448 Kbps
07.50hrs 05/05/08 Line Rate 7072 Kbps 448 Kbps
14.37hrs 05/05/08 Line Rate 7072 Kbps 448 Kbps
PN Speedtest
04/08/2008 10:44 4324 kbps (541kB/s) 364 kbps (45.5kB/s)
04/08/2008 17:47 4326 kbps (541kB/s) 379 kbps (47.4kB/s)
05/08/2008 08:06 4257 kbps (532kB/s) 377 kbps (47.1kB/s)
05/08/2008 14:41 5561 kbps (695kB/s) 366 kbps (45.8kB/s)
Your DSL connection rate: 7200 kbps, - 448 kbps
16.33 04 Aug 2008 Up time 8hrs 30min
Your DSL connection rate: 7072 kbps, - 448 kbps
Actual IP throughput achieved during the test was - 3575 kbps
08.12 05 Aug 2008 Uptime 1 day 0hrs 10min
Actual IP throughput achieved during the test was - 4118 kbps
14.52 05 Aug 2008 Uptime 1 day 6hr 50min
Actual IP throughput achieved during the test was - 5329 kbps
All this happened without prompting and without waiting another 3 days for things to stabilise after I tried rebooting yesterday.
Cheers
Bob
06-08-2008 12:16 PM
06-08-2008 3:01 PM
06-08-2008 4:47 PM
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 00:01:22:17
Line Coding Trellis Off Line Up Count 11
Line Rate 7616 Kbps 448 Kbps
Noise Margin 7.3 dB 23.0 dB
Line Attenuation 26.0 dB 14.0 dB
Output Power 19.8 dBm 11.9 dBm
something happend about 15.10 (Line Up Time updated) since I checked around at 14.40 and the stats were:
Latency Type Interleave Line Up Time 02:06:40:02
Line Coding Trellis Off Line Up Count 10
Output Power 19.7 dBm 11.9 dBm
Other parameters measured in the last few hours although the throughput is much the same at present.
Date Download Speed Upload Speed
Today 16:48 5561 kbps (695kB/s) 377 kbps (47.1kB/s)
Today 14:32 5563 kbps (695kB/s) 378 kbps (47.3kB/s)
Today 12:30 5611 kbps (701kB/s) 379 kbps (47.4kB/s)
Today 10:24 5452 kbps (682kB/s) 381 kbps (47.6kB/s)
12.30 06 Aug 2008 uptime 2days 4hrs 10min
Your DSL connection rate: 7072 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
Actual IP throughput achieved during the test was - 5269 kbps
16.53 06 Aug 2008 uptime 2days 8hrs 33min (now showing 1hr 22+min)
Your DSL connection rate: 7616 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
Actual IP throughput achieved during the test was - 5424 kbps
Does anyone know what the "Line Up Count " means since it increased from 10 to 11 over the same period ? I am quietly annoyed with myself for not noticing this figure earlier. I was concentrating on the other data which appeared to be more relevant
thanks
Bob
06-08-2008 5:04 PM
06-08-2008 5:41 PM
Regards.
12-08-2008 9:43 AM
- « Previous
- 1
- 2
- Next »
