Impatient for broadband activation!
- Impatient for broadband activation!
11-06-2010 6:23 PM
But since this morning my router has shown a green light for the phone line, but a red light for the internet.
What does this mean?
I have reset the router (an old Belkin) to factory defaults, entered my username / password as per instructions, and it is showing a downstream rate of 7616, upstream rate of 448 suggesting that BT has activated the line at the exchange. But no IP address...
I've read on this forum that Plus.net's equipment should automatically notice the login attempt and activate my connection. Is this true?
Re: Impatient for broadband activation!
11-06-2010 6:32 PM
Quote I've read on this forum that Plus.net's equipment should automatically notice the login attempt and activate my connection. Is this true?
That is correct, however it is worth noting that the routing between you and Plusnet may not have been completed by BT, this should clear either on or before the 15/6/10,
All i can suggest is leaving it connected, it will keep trying see if it connects. else its a waiting game until the 15th
13-06-2010 5:34 PM
14-06-2010 10:13 AM
If the router is in sync but you're unable to connect due to username and password it might be that the order has finished but not been closed off - if that's the case we can activate your account early if you like, just let us know. If you do you need to be aware that we can't raise any faults until the order is closed, and that you'll start paying subscription from the day the account is activated.
Hope that helps,
14-06-2010 5:22 PM
Should I open a ticket or phone?
14-06-2010 5:29 PM
That's now active for you
14-06-2010 10:56 PM
[Very impressed with Plusnet so far...]
15-06-2010 2:57 PM
Do I have to wait for the 10 days to be over before this will be sorted out?
15-06-2010 3:06 PM
15-06-2010 3:18 PM
Does it require manual intervention to change over to ADSL2+ or is that upgrade order automatic after successful activation
15-06-2010 3:24 PM
15-06-2010 5:18 PM
16-06-2010 9:24 AM
16-06-2010 9:41 AM
23-06-2010 5:51 PM
Have attached the BT Speedtester results and router stats. I am surprised the "Output power" in the upload speed is 0... is this anything to worry about?
Thanks.
