Im abit confused. help
mike360
Hi all im wondering if any of you can help does the wire between the junction box and the Test/Master socket count as my internal wiring?  Im abit confused
junction box >> white cable >> Test/Master socket (Bt or Ours responsibility)
Cheers
Fixes: 58
Re: Im abit confused. help
It's all a bit vague but as far as I know everything before the BT Master socket is theirs.
However, I just helped sort out the wiring in a house and all the sockets (upstairs and downstairs) were connected to the junction box by BT (it used jelly clamp connectors) so I just cut off the upstairs wire at the junction box leaving a single socket connected for the phone, broadband and Sky
Officially the master socket is the demarcation point, so the junction cable should be BTs to fix - that would need a fault raising on the phone line in order to investigate though.
Quote from: mike360
It depends where the junction box is in the circuit.
If it's between the incoming BT cable and the master socket backplate it's definitely BT's.
If it's between the master socket faceplate and your extension sockets it's yours.
Any other configuration and it may be debatable (and incorrectly wired).
