Im abit confused. help
- Im abit confused. help
30-03-2012 4:20 PM
Hi all im wondering if any of you can help does the wire between the junction box and the Test/Master socket count as my internal wiring? Im abit confused
junction box >> white cable >> Test/Master socket (Bt or Ours responsibility)
Cheers
Cheers
Message 1 of 4
(1,110 Views)
3 REPLIES 3
Re: Im abit confused. help
30-03-2012 4:35 PM
It's all a bit vague but as far as I know everything before the BT Master socket is theirs.
However, I just helped sort out the wiring in a house and all the sockets (upstairs and downstairs) were connected to the junction box by BT (it used jelly clamp connectors) so I just cut off the upstairs wire at the junction box leaving a single socket connected for the phone, broadband and Sky
Message 2 of 4
(453 Views)
30-03-2012 5:01 PM
Officially the master socket is the demarcation point, so the junction cable should be BTs to fix - that would need a fault raising on the phone line in order to investigate though.
Message 3 of 4
(453 Views)
30-03-2012 6:23 PM
Quote from: mike360 Hi all im wondering if any of you can help does the wire between the junction box and the Test/Master socket count as my internal wiring?
It depends where the junction box is in the circuit.
If it's between the incoming BT cable and the master socket backplate it's definitely BT's.
If it's between the master socket faceplate and your extension sockets it's yours.
Any other configuration and it may be debatable (and incorrectly wired).
Message 4 of 4
(453 Views)
