Idiot's guide to bridge mode
Fixes: 93
Re: Idiot's guide to bridge mode
@Junkman
Your public IP address is still responding to ping, what is the current setting for the Firewall on the Hub Two for
1) Incoming ping - YES or NO
2) DMZ - ON or OFF
Does the BQM graph looking normal (working)?
If not I would suggest disabling for a while to drop the BQM connection to you
Junkman
Incoming ping on Hub 2 is NO and DMZ is ON.  BQM graph still solid red.  What do I disable? Just disconnect the BT socket for 30mins?
Fixes: 453
I'd leave it until tomorrow in case this https://community.plus.net/t5/Broadband/Remote-pinging-of-my-Static-IP-stopped-or-blocked-at-midnigh... is affecting pings from outside the Plusnet networkk
Fixes: 93
@Junkman
I am referring to disabling the BQM graph found here, just below the graph on the Think Broadband site
HTH
Edit: disable it now and restart tomorrow morning
Junkman
@Dan_the_Van @MisterW when I clicked through to that page to disable it, the graph updated and it is WORKING again!
Fixes: 453
Sorry Dan I misunderstood
Junkman
Kicked back in at 5.30pm....
