IWF cache
- Re: IWF cache
IWF cache
12-04-2012 5:57 PM
Plusnet said it was an IWF cache problem and would impliment a fix
fix done according to plusnetr but no difference made,
nothing about this problem is mentiones anywhere
what I would like to know is how I get someone at plusnet to find out what the problem actually is and to fix it.
Re: IWF cache
12-04-2012 6:41 PM
Can you give any examples of the inaccessible sites?
Re: IWF cache
12-04-2012 7:02 PM
Re: IWF cache
01-05-2012 3:15 AM
"Needs adding to IWF cache update."
In response to "telnet postimage.org 80" working on some Plusnet connections but not others.
It appears to be working on all now, so looks as if someone has fixed it.
Keef- Sheerness Kent UK - Vodafone FTTP via THG3000 & Three via ZTE MF286D
Previously - NowTV, John Lewis, Shell Energy, Plusnet, Sky, EE, New Call Telecom/Fuelbroadband, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
Re: IWF cache
01-05-2012 7:33 AM
traceroute -T -p 80 postimage.org
traceroute to postimage.org (46.229.160.181), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 2.437 ms 9.575 ms 10.010 ms
2 lo0-central5.ptn-ag04.plus.net (195.166.130.83) 41.790 ms 44.974 ms 46.314 ms
3 84.93.253.83 (84.93.253.83) 28.085 ms 30.494 ms 31.551 ms
4 po4.ptn-gw01.plus.net (212.159.1.138) 33.888 ms 35.031 ms 37.374 ms
5 tun0.ptn-gw01.plus.net (212.159.2.101) 41.141 ms 42.084 ms 46.668 ms
6 vl69.ptw-gw02.plus.net (212.159.3.253) 47.087 ms 44.823 ms 39.379 ms
7 po4.ptn-gw01.plus.net (212.159.1.138) 40.923 ms 24.285 ms 23.841 ms
8 tun0.ptn-gw01.plus.net (212.159.2.101) 25.712 ms 24.039 ms 25.991 ms
9 vl69.ptw-gw02.plus.net (212.159.3.253) 24.668 ms 23.466 ms 23.268 ms
22 po4.ptn-gw01.plus.net (212.159.1.138) 29.332 ms 30.281 ms 29.910 ms
23 tun0.ptn-gw01.plus.net (212.159.2.101) 30.668 ms 30.727 ms 30.145 ms
24 vl69.ptw-gw02.plus.net (212.159.3.253) 30.019 ms 30.484 ms 29.902 ms
25 po4.ptn-gw01.plus.net (212.159.1.138) 28.467 ms 29.608 ms 30.045 ms
26 tun0.ptn-gw01.plus.net (212.159.2.101) 29.866 ms 30.164 ms 29.983 ms
27 vl69.ptw-gw02.plus.net (212.159.3.253) 30.419 ms 29.855 ms 29.134 ms
28 po4.ptn-gw01.plus.net (212.159.1.138) 30.333 ms 29.088 ms 29.377 ms
29 tun0.ptn-gw01.plus.net (212.159.2.101) 29.730 ms 47.780 ms 48.752 ms
30 vl69.ptw-gw02.plus.net (212.159.3.253) 30.328 ms 31.852 ms 30.710 ms
And fiddling with the MTU makes no difference.
Re: IWF cache
01-05-2012 7:43 AM
Quote from: purleigh It can also be a sign of having the MTU settings of your equipment being configured incorrectly.
I think that the way you've said that may be misinterpreted. The whole network should be capable of working with a default MTU of 1500.
Re: IWF cache
01-05-2012 8:09 AM
Re: IWF cache
01-05-2012 8:13 AM
Re: IWF cache
01-05-2012 8:34 PM
Quote from: ejs 4 po4.ptn-gw01.plus.net (212.159.1.138) 33.888 ms 35.031 ms 37.374 ms
Given the apparent routing loop between po4, tun0 and vl69, the MTU is irrelivant.
Re: IWF cache
01-05-2012 9:03 PM
Quote traceroute postimage.org
traceroute to postimage.org (213.174.142.28), 30 hops max, 60 byte packets
1 ROUTER (192.168.1.1) 1.902 ms 1.889 ms 17.254 ms
2 lo0-central7.pcl-ag03.plus.net (195.166.130.120) 33.924 ms 35.461 ms 35.455 ms
3 84.93.251.179 (84.93.251.179) 178.297 ms 178.293 ms 178.859 ms
4 tun0.pcl-gw01.plus.net (212.159.2.105) 178.852 ms 179.726 ms 179.717 ms
5 flowers2.servers.plus.net.uk (212.159.2.98) 50.795 ms 50.787 ms 52.157 ms
6 xe-11-1-0.edge3.London2.Level3.net (212.187.201.209) 66.755 ms 64.916 ms 65.480 ms
7 ae-0-11.edge4.London2.Level3.net (4.69.200.126) 42.667 ms 30.571 ms 31.337 ms
8 ae-3-3.ebr1.London1.Level3.net (4.69.141.189) 35.388 ms 35.384 ms 39.529 ms
9 ae-59-114.csw1.London1.Level3.net (4.69.153.126) 40.775 ms ae-58-113.csw1.London1.Level3.net (4.69.153.122) 42.694 ms ae-59-114.csw1.London1.Level3.net (4.69.153.126) 53.329 ms
10 ae-1-51.edge3.London1.Level3.net (4.69.139.73) 46.324 ms 49.383 ms 31.384 ms
11 IPTRIPLEPLA.edge3.London1.Level3.net (212.113.15.22) 31.826 ms 32.694 ms 32.687 ms
12 6-5.r0.101.dc5.eq.ash.va.us.iptp.net (91.194.117.159) 115.267 ms 114.898 ms *
13 ah.r0.101.eq.ash.va.us.iptp.net (98.158.98.254) 113.602 ms 112.417 ms 112.780 ms
14 213.174.142.28 (213.174.142.28) 113.336 ms 114.049 ms 113.768 ms
Re: IWF cache
01-05-2012 9:21 PM
root@ncc1701:~# tcptraceroute -p 80 postimage.org
traceroute to postimage.org (46.229.160.183), 30 hops max, 60 byte packets
1 skynet.avatastic.co.uk (10.0.1.1) 1.684 ms 1.014 ms 0.944 ms
2 lo0-central2.ptw-ag03.plus.net (195.166.128.48) 46.117 ms 27.400 ms 33.801 ms
3 gi1-16-321.ptw-gw01.plus.net (84.92.3.216) 37.765 ms 32.067 ms 50.790 ms
4 ae4.ptw-cr01.plus.net (195.166.129.36) 26.768 ms 43.103 ms 39.762 ms
5 te9-4.ptn-gw01.plus.net (195.166.129.33) 54.771 ms 35.146 ms 55.760 ms
6 tun0.ptn-gw01.plus.net (212.159.2.101) 39.636 ms 40.478 ms 28.789 ms
7 vl69.ptw-gw02.plus.net (212.159.3.253) 44.738 ms 41.626 ms 39.767 ms
8 po4.ptn-gw01.plus.net (212.159.1.138) 69.788 ms 24.958 ms 28.825 ms
9 tun0.ptn-gw01.plus.net (212.159.2.101) 40.751 ms 27.324 ms 53.667 ms
10 vl69.ptw-gw02.plus.net (212.159.3.253) 41.415 ms 62.607 ms 21.729 ms
11 po4.ptn-gw01.plus.net (212.159.1.138) 26.837 ms 48.425 ms 40.770 ms
12 tun0.ptn-gw01.plus.net (212.159.2.101) 26.802 ms 56.904 ms 22.951 ms
13 vl69.ptw-gw02.plus.net (212.159.3.253) 50.645 ms 23.377 ms 27.082 ms
14 po4.ptn-gw01.plus.net (212.159.1.138) 56.822 ms 29.249 ms 34.727 ms
15 tun0.ptn-gw01.plus.net (212.159.2.101) 27.801 ms 45.363 ms 25.815 ms
16 vl69.ptw-gw02.plus.net (212.159.3.253) 44.771 ms 25.273 ms 24.354 ms
17 po4.ptn-gw01.plus.net (212.159.1.138) 40.743 ms 22.309 ms 26.763 ms
18 tun0.ptn-gw01.plus.net (212.159.2.101) 55.784 ms 23.209 ms 25.783 ms
19 vl69.ptw-gw02.plus.net (212.159.3.253) 52.790 ms 26.258 ms 28.785 ms
20 po4.ptn-gw01.plus.net (212.159.1.138) 44.761 ms 28.503 ms 46.342 ms
21 tun0.ptn-gw01.plus.net (212.159.2.101) 32.079 ms 28.283 ms 68.780 ms
22 vl69.ptw-gw02.plus.net (212.159.3.253) 22.759 ms 25.089 ms 52.759 ms
23 po4.ptn-gw01.plus.net (212.159.1.138) 28.793 ms 56.935 ms 29.069 ms
24 tun0.ptn-gw01.plus.net (212.159.2.101) 28.778 ms 68.841 ms 25.788 ms
25 vl69.ptw-gw02.plus.net (212.159.3.253) 40.857 ms 28.467 ms 30.763 ms
26 po4.ptn-gw01.plus.net (212.159.1.138) 58.731 ms 26.285 ms 46.766 ms
27 tun0.ptn-gw01.plus.net (212.159.2.101) 98.290 ms 37.936 ms 36.654 ms
28 vl69.ptw-gw02.plus.net (212.159.3.253) 58.763 ms 43.100 ms 31.151 ms
29 po4.ptn-gw01.plus.net (212.159.1.138) 31.414 ms 27.471 ms 56.775 ms
30 tun0.ptn-gw01.plus.net (212.159.2.101) 28.801 ms 49.212 ms 29.757 ms
root@ncc1701:~#
via ptw-ag03
Re: IWF cache
04-05-2012 5:02 PM
Quote from: Keeef I just got this note on my questions page. :-
It's not been fixed yet.
