ISP or router to blame?
- Re: ISP or router to blame?
15-07-2013 1:02 PM
Saturday morning, internet was fine. Around midday-ish it suddenly stopped working. The router reported that it was still connected but I couldn't access anything via computer or iphone.
Tried running a ping test and got 75% packet loss. Couldn't get tracert to run.
Rebooted the router. Nothing.
Power cycled the router. Nothing.
Left everything off for a few hours. Internet back to normal.
Struggling to work out whether it's the router to blame or whether there's an internet issue. It's only happened once before, a few months back.
Thoughts?
15-07-2013 1:08 PM
For what it's worth, my Draytek 2710 is one of the most stable modem/routers I've ever used.
Does your 2710 have the latest firmware ? - http://www.draytek.co.uk/support/downloads.html
15-07-2013 1:12 PM
15-07-2013 2:56 PM
I regularly update to the latest firmware and did so after the first problem (in case it was the router).
15-07-2013 3:01 PM
Quote from: omens The router reported that it was still connected but I couldn't access anything via computer or iphone.
The iphone must have used a wireless connection to the router; how about the computer, wired or wireless?
15-07-2013 4:20 PM
I've posted a graph which shows your connection being down on Saturday:
<img src="http://community.plus.net/visualradius/generated/image13739011153908.png"/>
It looks ok now and there's nothing obvious that caused the disconnection.
I'd monitor your connection to see if this happens again.
15-07-2013 6:32 PM
Quote from: chrispurvey I've posted a graph which shows your connection being down on Saturday:
But is that the root cause or just omens rebooting and power-cycling the router, then leaving it off for a while?
15-07-2013 7:07 PM
Quote from: ReedRichards But is that the root cause or just omens rebooting and power-cycling the router, then leaving it off for a while?
+1. The two hour window is the same time I'd left the router off. The problem had started at midday, which shows me connected. The red/green bits show the attempts at rebooting the rooter.
15-07-2013 11:08 PM
15-07-2013 11:53 PM
16-07-2013 2:06 PM
16-07-2013 4:13 PM
