IPV6 ready router?
- Re: IPV6 ready router?
IPV6 ready router?
10-05-2011 4:52 PM
When will they be produced in mass, if they are now which would be a good one to possibly buy in the future?
Message 1 of 6
(1,494 Views)
5 REPLIES 5
11-05-2011 10:58 AM
HI antiFX,
Having a bit of a browse around google it seems that there are the odd one or two 'out of the box' IPv6 enabled routers but not a high demand at the moment.
Jojo
Jojo
Message 2 of 6
(599 Views)
12-05-2011 1:40 PM
I just stumbled upon this one: http://www.netgear.com/home/products/wirelessrouters/high-performance/WNDR3800.aspx ; the spec says 'IPv6 Support (Internet Protocol Version 6)' in the section marked 'standards'
Call me 'w23'
Message 3 of 6
(599 Views)
12-05-2011 1:51 PM
RIPE have been running a user-contributed survey to attempt to capture known CPE devices confirmed as supporting IPv6 (for various meanings of the word 'support'), the latest results of which can be found here.
Regards,
Mathew
Regards,
Mathew
Message 4 of 6
(599 Views)
12-05-2011 4:31 PM
Thanks i will look through these links.
Message 5 of 6
(599 Views)
12-05-2011 5:34 PM
On this topic ("IPV6 ready router?") I just found these links -
"How Do I Know If My Router Is IPv6 Compatible?" - http://www.pcadvisor.co.uk/opinion/network-wifi/3279518/how-do-i-know-if-my-router-is-ipv6-compatibl...
and from that page a link to a test to see what your setup is currently capable of - http://testmyipv6.com/
Message 6 of 6
(599 Views)
