IPAD MINI connectivity with Plusnet Technicolour router
keppy2008
HI
Thinking of buying the IPAD MINI .
Would it have good wifi connectivity via my fibre Technicolour  router....  positioned a  few rooms away.
Laptop connectivity is good , i am not sure if Ipad mini  would function as well ?
Anyone got this configuration ?
Cheers
KP Undecided
apjashley1
Re: IPAD MINI connectivity with Plusnet Technicolour router
Never had a problem, iPad mini's WiFi is pretty good
RJM
I have an iPod and iPad and no problems with the router supplied by Plusnet.
NorthEasterner
My speed stats Wireless (wifi) Wired (ethernet)
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
NorthEasterner
Quote from: JamieDanjoux
Sorry this was a mistake! can 1 of the mods please remove my reply? thanks
Jamie
