IP profile
- IP profile
IP profile
08-09-2010 10:56 AM
I completed a home move with plusnet a few weeks ago. My sync speed has been stable at over 7000 for about 5 days now but I'm still getting under 3mb download speeds.
I had a power cut yesterday which reset my router, the stats are below;
Link Information
Uptime: 0 days, 18:48:05
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,456
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 2.00
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 11.0 / 22.0
SN Margin (Up/Down) [dB]: 23.0 / 7.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 8 / 0
FEC Errors (Up/Down): 0 / 462,947
CRC Errors (Up/Down): 0 / 1,925
HEC Errors (Up/Down): 0 / 1,757
When can I expect my download speeds to increase? I imagine I should be getting around about the 6.5mb.
Thanks in advance.
Re: IP profile
08-09-2010 11:15 AM
I have checked you BT and PN profile and they are both showing 6000 so you should be getting somewhere near that. If you're only getting half of that then I would suggest having a look here for some tips.
Jojo
Re: IP profile
08-09-2010 11:27 AM
Re: IP profile
08-09-2010 11:51 AM
I don't see where your profile shows the old phone number but it was still showing the old exchange. I have changed this now, but it wouldn't make any difference to your speed/profile
Jojo
Re: IP profile
08-09-2010 12:50 PM
Re: IP profile
08-09-2010 1:16 PM
I'm having trouble finding your account. Do you have another username?
Jojo
Re: IP profile
08-09-2010 1:18 PM
Re: IP profile
08-09-2010 1:25 PM
I've just lifted it to 7150.
Jojo
Re: IP profile
08-09-2010 1:33 PM
Re: IP profile
08-09-2010 2:02 PM
Jojo
