IP profile
lauraak
IP profile
Hello I have done a bBTW performance test and it is saying the profile is capped at 2Mbs
 Download speed achieved during the test was - 1.95 Mbps
 For your connection, the acceptable range of speedsis 0.8 Mbps-2 Mbps.
 IP Profile for your line is - 2 Mbps
also i have carries out the dsl checker which comes back as
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 73.4 54.5 20 17.8 48.1 Available -- Yes Yes --
VDSL Range B (Impacted) 61.6 35 20 10 30 Available -- Yes Yes --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- -- -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 4 -- 2.5 to 6.5 Available -- -- -- --
ADSL Max Up to 3 -- 2 to 6 Available -- -- -- --
WBC Fixed Rate 1 -- -- Available -- -- -- --
so my question is, why is it capped so low and is this a normal speed to be receiving.
also the internet does seem to drop out quite often, the tech team have had a look and have said nothing is wrong .
i am currently using a brand new plusnet router, new microfilter, high speed ADSL cable in the test socket
any and all help would be much appreciated .
Fixes: 25
Re: IP profile
Can you please post your router stats.
Note you are comparing data speeds against synch speed estimates -,they are not the same metric.
Fixes: 205
Re: IP profile
Sorry to hear you're having issues.
Your speeds have restricted due to the amount of drops on your line shown below.
We need to get the drops sorted first and that in turn should bring your speeds back up.
I'd recommend raising a fault here
 Matthew Wheeler
