IP profile very different from current line speed
- IP profile very different from current line speed
15-10-2009 7:33 AM
I don't know if this is normal. Please help me.
My modem syncs with the exchange at 8128
BT Speedtester gives me a max achieveable and IP Profile speed of 7150
But my download speed is only 3070
Plusnet has a current line speed of 3500
I understand there are differences between the speeds, but is it normal for it to be so very large, especially between the IP profile and the Plusnet current line speed?
Message 1 of 3
(767 Views)
2 REPLIES 2
Re: IP profile very different from current line speed
15-10-2009 8:15 AM
This is quite odd
I've run a line test on your line which shows your IP profile as 3500kbps. I've also checked BT's line speed delta reports and that shows the same IP profile with a time stamp of 07/10/09. The strange thing is that this seems to have been generated from a sync event with a time stamp of 27/02/09.
I've altered the profiling at this side so try a reboot and let me know how you get on.
Message 2 of 3
(306 Views)
15-10-2009 8:58 AM
Firstly, thank you so much for your fast reply.
I've rebooted and run three different tests with different speed testers. I'll do a BT speedtest once my 3 hours are up.
However, the other tests show download speeds of between 6.2 and 6.6 Mbps, double what I had before, which is utterly fantastic.
So you fixed my problem and have a very satisfied customer.
Jon
Jon
Message 3 of 3
(306 Views)
