IP profile remaining lower then download speed?
- Re: IP profile remaining lower then download speed...
30-05-2014 9:06 AM
I had my noise margin reset the other day from a stuck 9db to 6db. Within a couple of days my download speeds came up from 7Mb to 9Mb. On the BT tester my IP profile has stayed at the original rate of 8.56Mbps which is lower than the current (and stable for over 4 day) download speed. Can this be corrected to reflect my new and stable rate?
Dave
Dave
Message 1 of 3
(569 Views)
2 REPLIES 2
Re: IP profile remaining lower then download speed?
30-05-2014 9:32 AM
Hi davebd,
I've just taken a look at your line. You're syncing at 11227K which should give you an IP Profile of around 9902K. If your IP Profile is still reporting lower, can you let us know and provide a screenshot of the BT Speedtester result?
Message 2 of 3
(390 Views)
30-05-2014 9:47 AM
Hi Chris, I have attached the results from BT speedtester as you asked
Dave
Dave
Message 3 of 3
(390 Views)
