IP profile question
FIXED- Subscribe to RSS Feed
- IP profile question
25-02-2017 4:13 PM
If my router is synced to the exchange at 12903 Kbps, what should my IP Profile be approximately?
Fixed! Go to the fix.
Re: IP profile question
25-02-2017 4:17 PM
25-02-2017 4:29 PM
Thanks. It's ADSL2+ and the calculator in the link is showing a Profile of 11000 kbps. How long should it take for the IP profile to match the BT value? Days?
I ask because the DLM has decided that my line is stable enough for a noise margin of 3.3dB and adjusted the sync speed to suit. The line is perfectly stable but the IP profile hasn't changed, yet.
Incidentally, I just had an interesting conversation with an agent who was adamant that I can't possibly be getting that kind of speed because it's twice what BT say it should be. Well, it is and I am!
25-02-2017 4:36 PM - edited 25-02-2017 4:39 PM
The calculator is for ADSL1.
For ADSL2+ the profile is 88·2% of the sync. It should change up or down within minutes if the sync changes.
There was a time when PN were slow to catch up with the BT profile, but I thought that was all sorted now.
FTTC 40/10 Billion 8800NL
BT technician (Retired)
25-02-2017 4:43 PM
The sync speed was raised two days ago, still the same IP Profile though.
25-02-2017 4:52 PM
What are you using to see the IP Profile?
The Plusnet Current Line Speed doesn't seem to limit the speed on the new network anyway.
25-02-2017 5:39 PM - edited 25-02-2017 5:40 PM
I'm using https://portal.plus.net/my.html?action=data_transfer_speed
So the IP profile should be around 11530kbps. It's actually showing less than 10 on that link. I know it's quite fast, but every little helps!
25-02-2017 6:01 PM
Presumably the BT speedtester further diagnostics (don't reboot anything, ignore all the text in red, just run the test) shows the correct IP profile?
The Plusnet Current Line Speed always seemed about as quick and reliable to update as sending a letter through the post.
25-02-2017 6:12 PM - edited 25-02-2017 6:12 PM
The BT speedtester won't run the "further diagnostics" section. Just returns an error message saying an error has occurred! So I can't check what BT thinks the profile is. It's been like that for months!
25-02-2017 7:54 PM - edited 26-02-2017 9:15 AM
Sorted! Managed to chat to someone who understood what I was saying.
Looks like the PN IP Profile system still needs a nudge on occasions.
Thanks for replying folks!
