IP profile is not updating
backtogeek
Hi All,
After getting no where with the official support channels I decided to make a post over on kitz forum (some very helpfull people over there)!
So here is my issue in a nut shell.
Connection Speed 1824 kbps 448 kbps
Line Attenuation 61.0 db 31.5 db
Noise Margin 10.9 db 19.0 db
WAN Uptime: 133:18:07
IP Profile is at 1250 and should be at 1500
When I spoke to plusnet CS I was told that because my line is syncing close enough to my initial line prediction plusnet simply would not help....... thanks!
Perhaps I have this wrong but I dont think that what ever the magic BT equipment is that decides your IP profile is open to opionions if the sync numbers are high enough then logic takes over and should up scale the ip profile to match?
And the other problem with this whole thing is that the line will sync at 2272 if I unplug the telephone which should not happen and I have been informed this is likley a high resistance fault?
Router is in the test socket and no ext in the house at all.
Hope someone can help?
jojopillo
Re: IP profile is not updating
Hi backtogeek,
I'll take a look at this now and get back to you shortly, see what I can find out.
Jojo Smiley
pierre_pierre
Welcome to the PN forums
Can you give us the router stats in the test socket without the phone?
backtogeek
Sods law the dog pulled the cable out of the wall 10 minutes ago so my connection time has reset.
Will do a sync with the phone out and post results soon,
jojopillo
Hi backtogeek,
I know you have probably done all sorts of checks by now, but so I could run a test now, would it be possible for you to plug your filter into the test socket and let me know so I can continue to try to resolve this for you.
Thank you,
Jojo Smiley
backtogeek
Hi jojo,
Thanks for this.
Router is now in the test socket
jojopillo
HI backtogeek,
Thanks I'll check that again now for you.
Jojo Smiley
jojopillo
Hi backtogeek,
Are you sure you're in the test socket as there is absolutely no difference?
Jojo Smiley
backtogeek
Sorry for the confusion the router has allways been in the test socket.
synced at 1856 yet the IP profile is 1250 on the BT test site
jojopillo
Hi backtogeek,
Ok I'll try resetting your line and see if that kicks it into action.
Jojo Smiley
backtogeek
WOW
Not sure what you did there but here are my router stats:
Connection Speed 2720 kbps 448 kbps
Noise Margin 1.1 db 19.0 db
massive jump.
IP Profile is still at 1250
Given that the sync speed has jumped up by 46% the profile should update in 12 hours with Adaptive Max Logic?
jojopillo
We'd hope so. Just need to play the waiting game now making sure you don't reboot at all Smiley
backtogeek
Thanks Joanne,
I just want to say I realy appreciate this in an afternoon you have helped me achive what I have been trying to get through the standard support since 20/11/2010
The ticket I have does not exactly contain everything that was said on the phone for probably obvious reasons.
Could you PM me your office address and managers name please or email I would like to write in about this.
If this works and holds steady I will be ordering an additional 3 BT lines through plusnet and bonding them, which will give me the sort of speeds I actualy need (work from home) I am going through 3G card bandwidth allowances like pea nuts right now.
dick:quote
backtogeek
My IP profile is still at 1250 Sad
Noise Margin 1.5 db 19.0 db
WAN uptime: 22:16:14
I think I had a very brief drop out at arounf 10:34 this morning as I noticed in the log that the SNR dropped to 0 (running routerstats 6.6) but apart from that the line had been synced way more than 12 hours so I still belive there is a problem and my IP profile is 'stuck'
Ant.
jojopillo
HI Ant,
I'll do some digging then and see what I can come up with.
Jojo Smiley
