IP profile dropped
mcilroyclan
IP profile dropped
My sync speed has dropped from a steady 2.8Mb to 2.2Mb. Also the target SNR seems to have increased from 6db to 9db. I suspect I caused the problem by tweaking my SNR too aggressively resulting in a lot of disconnects and caused the DLM to decrease the speed. How can I get it back to 2.8Mb?
May not seem like a lot but every little helps when you're on a slow connection like mine Smiley
Fixes: 162
Re: IP profile dropped
Your target SNR is still 6db:
 Profile Info: BT WBC 8M/Uncapped/6dB/Interleaved (ADSL)
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 34.5 60.0
SNR Margin: 10.5 6.0
Errored Seconds: 0 0
HEC Errors: 0
Cell Count: 318 318
Speed: 544 2464
The target is 6 and your line is currently at 6db too :/
 Chris Parr
 Plusnet Staff
mcilroyclan
If you check again you'll see its 9db. Could I get a line reset?
Fixes: 20
You seem to be provisioned on ADSL1. Have you considered getting that changed to ADSL2+? It might be better, it might be worse, you won't know unless you try it. If you can tweak the SNR, I expect you'd be capable of setting the mode yourself if necessary, once it's provisioned as ADSL2+ (you'd probably want to be using ADSL2, but Plusnet can either set it for ADSL1, which only allows ADSL1, or for ADSL2+, which allows ADSL1, ADSL2 and ADSL2+).
My attenuation (58 dB) isn't quite as high as yours, but it manages fairly well on ADSL2 at a 3 dB target SNR margin.
