IP profile dropped
- Re: IP profile dropped
IP profile dropped
26-05-2016 11:20 PM - edited 26-05-2016 11:21 PM
My sync speed has dropped from a steady 2.8Mb to 2.2Mb. Also the target SNR seems to have increased from 6db to 9db. I suspect I caused the problem by tweaking my SNR too aggressively resulting in a lot of disconnects and caused the DLM to decrease the speed. How can I get it back to 2.8Mb?
May not seem like a lot but every little helps when you're on a slow connection like mine
27-05-2016 11:21 AM
Your target SNR is still 6db:
Profile Info: BT WBC 8M/Uncapped/6dB/Interleaved (ADSL)
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 34.5 | 60.0 |
SNR Margin: | 10.5 | 6.0 |
Errored Seconds: | 0 | 0 |
HEC Errors: | 0 | |
Cell Count: | 318 | 318 |
Speed: | 544 | 2464 |
The target is 6 and your line is currently at 6db too 😕
27-05-2016 8:06 PM - edited 27-05-2016 8:09 PM
If you check again you'll see its 9db. Could I get a line reset?
27-05-2016 8:40 PM
You seem to be provisioned on ADSL1. Have you considered getting that changed to ADSL2+? It might be better, it might be worse, you won't know unless you try it. If you can tweak the SNR, I expect you'd be capable of setting the mode yourself if necessary, once it's provisioned as ADSL2+ (you'd probably want to be using ADSL2, but Plusnet can either set it for ADSL1, which only allows ADSL1, or for ADSL2+, which allows ADSL1, ADSL2 and ADSL2+).
My attenuation (58 dB) isn't quite as high as yours, but it manages fairly well on ADSL2 at a 3 dB target SNR margin.
