IP change
- Everything else
- IP change
IP change
a week ago
Re: IP change
a week ago - last edited a week ago
- DELETED - I misread the question ! ![]()
Re: IP change
a week ago
@ExForce9 The OP wants to move from static to dynamic
Re: IP change
a week ago
Re: IP change
@rob1969 - out of curiosity, why? And note that because PN IPs are sticky, it may not change.
Re: IP change
Why would you want to do that ?
You are MUCH less likely to have problems with IP-blocking or geo-location services by being on a static !
I would much prefer to be on the Plusnet "high touch" (static) network, than the Plusnet "low touch" (dynamic) circuits.
Re: IP change
a week ago
@rob1969 whilst a dynamic ip would be different to your current static, rebooting the router does not necessarily change a dynamic ip to a new one. Dynamic ips are allocated from small pools these days are so are quite 'sticky'
Re: IP change
a week ago
@rob1969 wrote:
I just want to go to dynamic so that my IP address changes when I reboot my router
In the coming weeks when Plusnet finally rolls out IPv6 on your Plusnet Hub Two, your WAN will be allocated a static IPv6 block of addresses, and your network connections will prefer connecting via IPv6 rather than IPv4, so whatever you are trying to achieve with a dynamic IPv4 WAN will likely be thwarted by your device addresses always being allocated within the same IPv6 subnet.
Re: IP change
a week ago
Rather than attempting to get a new IP address by rebooting your router - which disrupts all the devices on your LAN
have you considered using a VPN on the devices that you want to change your address on ?
I use Proton VPN which gives me decent speed and minimal latency, with 929 servers in the UK to choose from.
Re: IP change
a week ago
Thread moved from Broadband to Everything Else
Re: IP change
Monday - last edited Monday
Is your static IP one you specifically requested and paid for in the past? Or is it simply long term static by default? I ask because, if the latter, it may possibly be a do-it-yourself job!
Re: IP change
Monday
I think its long term by default,the reason I wanted to change is because someone found out my IP and was posting it around a gaming forum, but on reading up on the risks there aren't many I guess so I suppose I will leave it
Re: IP change
"I think its long term by default"
In which case look to your Plusnet account settings. You may have the old Plusnet Firewall ON (as I do) - not the router firewall. This depends on a static IP. If you have the firewall on you can turn it OFF, reboot your router, and leave the firewall OFF. Or, turn firewall off, reboot your Hub 2 router and, if now a different IP, switch the firewall on again if you wish; this will keep the new IP static.
