IP address
Soozy
IP address
After doing 2 speed tests on different days, I noticed that a different IP address is showing for each speed test. Surely, this isn't right? The only thing I've done since the first test is to reset the router to factory settings, as advised by Plusnet.
Fixes: 162
Re: IP address
Unless you've added a static IP through the add-ons section of the website then you will have a new IP address each time you disconnect/reconnect to the Internet.
 Chris Parr
 Plusnet Staff
Soozy
Re: IP address
OK, thanks - that's cleared that up - I wasn't too sure.
