IP address on blocklist after bug bounties
Jordanweaver1
I started to try bug bounties and must have got carried away as my ip seems to have been put on some sort of block list, I'm unable access websites like ebay and Disney plus. Is there any way to get my IP removed from the list?
7 REPLIES 7
Legend
Fixes: 255
Re: IP address on blocklist after bug bounties
@Jordanweaver1 Can you access any sites?
Jordanweaver1
Hi, yes pretty much all websites, in fact Disney plus and ebay are the only ones I've tried that have been blocked. It's just annoying as my wife uses ebay quite a lot.
Legend
Fixes: 255
You could try and obtain another address, but it may not work and is a pain. Disconnect your Hub, switch it off for at least 65 minutes, and then see if your IP changes. This assumes you are on a dynamic IP.
Fixes: 419
@Jordanweaver1
You could use a free VPN for those sites.
YouKnowIThatGuy
Surely if you are an "ethical hacker" you can resolve this issue by yourself, right?
Give you a clue. It starts with a V and P and an N.
Jordanweaver1
I don't think the wife would want to use a vpn everytime she wants to stick something on disney for the kiddo. Fortunately this resolved itself after a day or two
YouKnowIThatGuy
Good to hear, sounded like some kind of temporary IP ban.
