IP adderss -- FIrst octet now 81 ?
- Re: IP adderss -- FIrst octet now 81 ?
11-11-2010 7:07 PM
I rarely check my IP address these days, but happened to tonight and noticed the first octet is 81
que pasa?
11-11-2010 7:23 PM
If you use the gateway checker does that give you an answer? It won't if the IP isn't in a recognised range.
11-11-2010 7:33 PM
Just seemed odd that after so many years, this seemd to be the first time I got a 81.xxx ... wondered if there were changes to the network afoot.
11-11-2010 7:38 PM
Just because I might be paranoid, doesn't mean they aren't out to get you!
Quote #! /bin/bash
date_stamp=$(date +%d/%m/%Y@%X)
exip=$(wget -qO - checkip.dyndns.org | grep -Eo '[0-9\.]+')
echo "$date_stamp $exip" >> /var/log/whatismyip.log
I haven't noticed any 81.x.x.x ip addresses though.
11-11-2010 7:44 PM
tracert portal.plus.net | awk '{if($1~2){print $8,$9}}' >> gw.dat
nslookup mydyndnsaddress.dyndns.org | awk '{if($2~/87/){print $2}}' >> gw.dat
Not as elegant as Linux, but then cmd isn't bash
11-11-2010 7:50 PM
11-11-2010 8:29 PM
11-11-2010 9:00 PM
11-11-2010 9:02 PM
11-11-2010 9:06 PM
tracert -h 2 ntp.plus.net
11-11-2010 9:09 PM
11-11-2010 9:11 PM
