IP Stream Connect: Incorrect profiling alert
- IP Stream Connect: Incorrect profiling alert
28-06-2009 6:11 PM
See Reply #8 for why this topic has been renamed. All trialists need to read that post.
It's broken!
I started a download and found it was going to be several hours. Reconnected to RIN and it said complete in 12 minutes, reconnected to normal (plusdsl.net) and it said a similar time, reconnected to IPSC and it's back to taking hours. You can see what's happening very clearly on the attached NetMeter graph.
I then looked at a Wireshark trace - see attached screen dump.
0x60 on PAYG!
Re: iPlayer download, PAYG on IPSC
28-06-2009 6:53 PM
29-06-2009 9:31 AM
[quote author="Ticketing system"]Ticket: 29225792
29/06/09 05:07
The Customer Closed: Provisioning of your ADSL Account Information
ADSL Realm change from \"plusdsl.net\" to \"plus11.net\"
[quote author="Ticketing system"]Ticket: 29221915
28/06/09 05:08
ADSL Realm change from \"plus11.net\" to \"plusdsl.net\"
[quote author="Ticketing system"]Ticket: 29193943
25/06/09 05:06
Unless you were connected on the @plusdsl.net realm betweeen 28/06/09 05:08 and 29/06/09 05:07 you would have been getting a Broadband Plus experience.
29-06-2009 10:30 AM
What confused me at first was that I've switched realm many times more than 12. It appears that the ADSL realm only changes once per day (the times on the tickets are all in the range 5:06am to 5:10am).
How does it decide which realm it is going to change to, I'm pretty convinced that after every time I've experimented and done comparisons across the different realms in the past I've left it on plus11.net when I've gone to bed (although it is possible that I've left it on RIN once or twice). However last night, because IPSC was giving dire speeds I left it on plusdsl.net, yet overnight it change my realm to plus11.net!
I've just tried another download and I'm currently getting the correct speeds on both realms - how come? As my realm is now plus11.net surely on plusdsl.net I should be being assigned the BB+ profile (or is it because 10am is the off-peak for BB+ and hence the speeds are not too bad).
Will this mess up with my domain affect my peak/off-peak usage recording? (PAYG is 8am to midnight and I believe BB+ is 4pm to midnight)
29-06-2009 11:08 AM
You'll probably be getting full speed at the moment (unless it's P2P or Usenet) on the default profile because there are no rate limits and the traffic priorities aren't doing anything as there's spare capacity at this time of day.
Plusnet Technology
29-06-2009 11:20 AM
If I'm on the wrong realm, is there a way I can be forced back on to the correct realm or do I have to wait until the next day?
30-06-2009 1:31 PM
[quote=Ticketing system]Your comment 5:07am, Tuesday 30th June 2009
30-06-2009 7:28 PM
My normal streaming speeds on this test are well over 6000.
To add insult to injury I've just found this comment on my open ticket about this:
Quote [Name Removed] IE - Generic 4:08pm, Tuesday 30th June 2009
[Internal] Profiling is fine for the application. 0x60 = Gold-Plated. I'm guessing this was the customers point. The speed does not reflect the profiling of the application.
I have added my own comment to the ticket.
I think Mand needs to get the educating tool out!
01-07-2009 10:53 AM
It is possible that you are being profiled as Broadband Plus and not your normal profile. The main symptom you would see if this is the case will be that download speeds will be significantly restricted between 4pm and midnight. As noted above it is because of swapping between the normal login domain and the plus11/plus12 login domain.
We were originally told that we would be able to swap between the two without any problems - it now transpires this is not the case.
To confirm if this is the case look at your closed tickets. You will find tickets looking those quoted by Bob in Reply #2. You need to find the latest of those tickets. If it says your domain has been changed to plus11.net or plus12.net (depending upon whether you were one of the first 20 or the later 5 trialists) your Ellacoya profiling will be correct on IPSC and incorrect if you try your normal login (you'll get the default BB+ profile). If it says your normal login domain you will be being incorrectly profiled on IPSC but correctly profiled on your normal login.
It seems to flip flop the domain if just once during the day you log in with the other domain. So if you are on plus11 for some time and briefly log in to your normal domain for 5 minutes to do a comparison before returning to plus11 for the rest of the day, at 5am the next morning your domain will revert to your normal domain.
The strange thing I've found is that it isn't only changed when you reconnect.
Monday I swapped domains a couple of times. I connected to plus11.net at around 17:30 and have remained connected to that domain ever since.
Tuesday 5am domain was swapped to plusdsl (incorrectly profiled all day - luckily I was in London for most of the day)
Wednesday 5am domain swapped to plus11 (even though I didn't reconnect at all yesterday - router reports connection up for 41 hours)
Re: IP Stream Connect: Incorrect profiling alert
01-07-2009 11:16 AM
My latest and only ticket on the realm change confirms I am on plus12.dsl, and I have not tried to revert back. Last night at 8:30pm a virus database update downloaded at ~50kB/s, which is consistent with what I believed was my assigned IP profile at that time (500kbps, although it now appears to have increased to 1500kbps even though it's only 30 hours since the line rate increase).
01-07-2009 11:27 AM
Don't shout too loudly - (checking on Kitz camparison) everything except External FTP on that profiling is better than Value
Quote from: jelv You need to find the latest of those tickets. If it says your domain has been changed to plus11.net or plus12.net (depending upon whether you were one of the first 20 or the later 5 trialists) your Ellacoya profiling will be correct on IPSC and incorrect if you try your normal login (you'll get the default BB+ profile).
01-07-2009 12:27 PM
Well you know what to do then!
